![]() | Home > General > need some advice, sell it and cut my losses or continue... |
Ianmaney Member Since: 27 Nov 2012 Location: Birmingham UK Posts: 118 ![]() ![]() ![]() |
I had a V8 Disco 2 withh LPG conversion on it up till a month ago, i bought it Feb last year, ive been slowly rebuilding it to a point where it was perfect, then it needed MOT-ing and the gas needed a service, it needed welding to the chassis for the mot, this required the gas tanks removing, i then find out the tanks were leaking, then the sender unit in the petrol tank went U.S, so i sold it and got my current car, L322 Vogue, 03my, TD6 and have never been happier, i can get in, turn the key and simply drive it, not think about the next repair etc, so to be honest, id get rid of it and get a better one, just my opinion you understand, hope it all works out for you !!! |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
And that's exactly the reason I bought a TD6 and not a V8 with LPG. Why make a complicated car more complicated ?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8541 ![]() ![]() ![]() |
Most cars don't like not being used and it sounds like yours was stood for a long time, gathering condensation in all the places you want to keep water from....
woodchip Member Since: 19 Apr 2012 Location: cumbria Posts: 132 ![]() ![]() ![]() |
SELL, SELL, SELL. The can of worms will only become larger and swallow up more money, never mind people saying fix this then fix that, it seams to me the car has had its day or as far as common sense ���� is concerned. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35649 ![]() ![]() |
there's always a better FF out there and yours seems to be having a few problems, if you can afford to do it ,sell and find a nicer one.. ... - .- -.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2279 ![]() ![]() ![]() |
Have to agree with the majority sell and buy another |
@James,
James4287 Member Since: 08 Jun 2014 Location: Cornwall Posts: 20 ![]() ![]() ![]() |
Thanks for the replies, im still not sure. I have the use of an engine crane air tools and a 4 post ramp, i also have somewhere to keep it and if its not finished in the next two years im not fussed. I'm in no rush and in 2 years time im sure it will still be worth 3 grand atleast by then it will be 100% fixed and usable reliably. Ultimately i have other cars and have no urgancey to get it back on the road.
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Given you have the facilities and by the sound of it you are pretty handy with a set of spanners, I would get the engine and cooling system checked out for leaks or HGF. You can then make a decision to cut an run, or fix based on the level of work required. 56 TDV8 Vogue SE
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
As Andy says above, first step would be to get a sniff test of the expansion tank for exhaust gases, if it's HGF then probably worth getting rid of it.
With the cost of a replacement engine, would the FFRR be at market value, below or over ?? If it is over market value (and from your post it may still not be the case) then it makes economic sense to dump it now. Which doesn't mean you should but it would make sense.
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
New engine time, by the looks of it.
If you keep it and you seem to do low miles then please keep the new(er) engine LPG free. As said before do not complicate matters to save a few pounds on fuel.
