![]() | Home > Maintenance & Mods (L322) > car won't start |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
Battery not as good as it should be if the indicator is black, should be green, you can charge it ot see if it will recover but it might not. Do you do short runs ? can check the alternator when you get the FF running. If it dont work.......burn it!
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Thanks for reply wd. I put tester on battery and its coming up at 11volts, all interior lights have gone dim. Just need to know if I can use a mains booster or not?
I cant see why not, I have charged my FF with the battery in the car, its a trickle charger though. If it dont work.......burn it!
Ok cheers |
All ok now got a taxi down to halfrauds 120 quid so not to bad. Installed , lock to lock and away again. This battery a bit bigger 100ah and 900 a with a 5yr guarantee |
Check your alternator its pushing 14 volts + too, just to discount that. If it dont work.......burn it!
Cheers will do |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
Hi.
Mjd cheers. Old battery was 95ah and 800a . Handbook states 90ah to 110ah so I'm in the middle. Plus halfords not too far from me, so was easy to get to quick |
