Home > Maintenance & Mods (L322) > car won't start
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
car won't start
Went to do shopping and car wont start. Looked at battery and black dot shows on top. It has an exide excell 95ah 800a fitted is this a bit under what it should be. Can I connect a mains booster or not. Please help as I'm stuck.
thanks in advance
greg
Post #284997 8th Oct 2014 10:44am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Battery not as good as it should be if the indicator is black, should be green, you can charge it ot see if it will recover but it might not. Do you do short runs ? can check the alternator when you get the FF running. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #285001 8th Oct 2014 10:56am
gregdav
Thanks for reply wd. I put tester on battery and its coming up at 11volts, all interior lights have gone dim. Just need to know if I can use a mains booster or not?
greg
Post #285002 8th Oct 2014 11:01am
Welshdragon
I cant see why not, I have charged my FF with the battery in the car, its a trickle charger though. If it dont work.......burn it!
Post #285004 8th Oct 2014 11:08am
gregdav
Ok cheers
Post #285005 8th Oct 2014 11:09am
gregdav
All ok now got a taxi down to halfrauds 120 quid so not to bad. Installed , lock to lock and away again. This battery a bit bigger 100ah and 900 a with a 5yr guarantee Very Happy
thanks again. Thumbs Up
Post #285059 8th Oct 2014 3:01pm
Welshdragon
Check your alternator its pushing 14 volts + too, just to discount that. If it dont work.......burn it!
Post #285068 8th Oct 2014 3:59pm
gregdav
Cheers will do Thumbs Up
when it stops thunder & lightning, & raining Sad
greg.
Post #285071 8th Oct 2014 4:11pm
mjdronfield
Hi.
You say it's a bit bigger at 100 amp, but the td6 needs a 110amp as standard I believe.
What amp was the old one ?
You should be fine unless you plan on moving to the Antarctic, plus the 5 year guarantee is good.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #285104 8th Oct 2014 7:05pm
gregdav
Mjd cheers. Old battery was 95ah and 800a . Handbook states 90ah to 110ah so I'm in the middle. Plus halfords not too far from me, so was easy to get to quick Wink
been out tonight and all working fine Thumbs Up
Post #285129 8th Oct 2014 8:59pm
