Home > Maintenance & Mods (L322) > Front Disks / Brake Judder |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Hi ya bud, glade to see you've taken the plunge and saved squillions of dosh and decided to diy!
29th Sep 2014 4:38pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7792 |
Many thanks miggit, I have purchased 5 litres of cleaner from a motor factors for the same price Halfrauds would want for 1 litre.
1st Oct 2014 12:32pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
Mark, don't think you will have Brembo brakes on yours.... Or are they standard parts made by Brembo?? Pete
1st Oct 2014 2:12pm |
Hi Pete,
1st Oct 2014 2:16pm |
That should sort it, if you have trouble fitting them, you've got my number...
1st Oct 2014 2:35pm |
Hi Mark, IF your pads have a backing on them, you will only need to put a very small amount of copper grease on the sides of the pad that make contact with the calliper bracket. But if the back of the pad has no obvious anti squeal coating (normally looks like a sticker 3/4 mm, or a couple of 20 mm heavily painted strips) you will need to put some grease on them too. The ECB pads that I used on mine came with the anti squeal shims unattached, and I had to fashion them in the right shape and stick them on. Basically I hacked them up with the kitchen scissors, pealed the backing, stuck them in place and then trimmed them with a Stanley knife. Good luck Bud you have the help line if needed Yesterday I couldn't spell Engineer... Today I are one!
1st Oct 2014 10:28pm |
Many thanks Gents,
2nd Oct 2014 7:05am |
Advanced Factors Site Sponsor Member Since: 31 May 2013 Location: Southampton Posts: 196 |
Just a small smear of copper grease on the contact area of the "ears" of the pads, no point in putting anything on the back. Paul Redding
2nd Oct 2014 9:31am |
Hi Mark, as Steve said, just a small smear of grease on the ears will suffice. basically the area that you can see between your finger and thumb in the second photo, it is literally the bottom of the ear and the outside face, and only needs to be the thin part
2nd Oct 2014 10:31am |
Cheers.
2nd Oct 2014 10:34am |
Dam your quick on that keyboard I was editing my reply to include the pins!! Yesterday I couldn't spell Engineer... Today I are one!
2nd Oct 2014 10:40am |
So do you have new brakes, on the car? Yesterday I couldn't spell Engineer... Today I are one!
4th Oct 2014 10:14am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1750 |
A wire brush and a bit of spray grease works wonders on the sidle pins |
4th Oct 2014 10:27am |
Well, being honest, I had to bail out. Could not undo the 16mm bolts that held the caliper to the hub. The little grub screws were fine though.
4th Oct 2014 10:57am |
I feel for you bud, did I not mention that a 24" breaker bar was a preferred item in the toolbox, sorry! Its such an essential item that I just take it for granted everyone has one, but for some reason they are never included in any master mechanic socket set. And yet I challenge anyone to find a processional mechanic who doesn't own at least 1. I have 4! In different sizes, 4 the same size would be excessive
4th Oct 2014 2:40pm |
