![]() | Home > Maintenance & Mods (L322) > Front Disks / Brake Judder |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Hi ya bud, glade to see you've taken the plunge and saved squillions of dosh and decided to diy!
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7912 ![]() ![]() ![]() |
Many thanks miggit, I have purchased 5 litres of cleaner from a motor factors for the same price Halfrauds would want for 1 litre.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
Mark, don't think you will have Brembo brakes on yours.... Or are they standard parts made by Brembo?? Pete
Hi Pete,
That should sort it, if you have trouble fitting them, you've got my number...
Hi Mark, IF your pads have a backing on them, you will only need to put a very small amount of copper grease on the sides of the pad that make contact with the calliper bracket. But if the back of the pad has no obvious anti squeal coating (normally looks like a sticker 3/4 mm, or a couple of 20 mm heavily painted strips) you will need to put some grease on them too. The ECB pads that I used on mine came with the anti squeal shims unattached, and I had to fashion them in the right shape and stick them on. Basically I hacked them up with the kitchen scissors, pealed the backing, stuck them in place and then trimmed them with a Stanley knife. Good luck Bud you have the help line if needed |
Many thanks Gents,
Advanced Factors Site Sponsor Member Since: 31 May 2013 Location: Southampton Posts: 198 ![]() ![]() |
Just a small smear of copper grease on the contact area of the "ears" of the pads, no point in putting anything on the back. Paul Redding
Hi Mark, as Steve said, just a small smear of grease on the ears will suffice. basically the area that you can see between your finger and thumb in the second photo, it is literally the bottom of the ear and the outside face, and only needs to be the thin part |
Cheers.
Dam your quick on that keyboard |
So do you have new brakes, on the car? |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1815 ![]() ![]() |
A wire brush and a bit of spray grease works wonders on the sidle pins ![]() |
Well, being honest, I had to bail out. Could not undo the 16mm bolts that held the caliper to the hub. The little grub screws were fine though.
