Home > Maintenance & Mods (L322) > SC leaking oil - Ladder Frame... Or something |
RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 222 |
Worth checking that it is not running down from the cam cover gaskets. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
18th Sep 2014 4:01pm |
Thanks RRBlue, will check.
18th Sep 2014 4:47pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
jeez, that looks alarming ryan....hope its not to much of a sort out.. ... - .- -.
18th Sep 2014 5:07pm |
Would just like to know what the components covered in oil and as pictured are Stan.
18th Sep 2014 7:46pm |
87RJD Member Since: 01 Dec 2013 Location: Wokingham Posts: 103 |
Looks like the front diff casing to me, you can see the prop shaft connected to it SC 4.2, 2012 face lifted, 25K miles, 1 previous owner
18th Sep 2014 7:50pm |
Thank you, it does look new and the front diff was replaced recently.
18th Sep 2014 8:30pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1775 |
Have seen the sump/crankcase leak on the 4.2 before.
18th Sep 2014 8:35pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8621 |
Would be strange if the seals had gone already. Take it back get them to sort it. There is nothing that can't be fixed with a hammer๐๐
Reduced engine power in April resulted in the SC water pump and crankcase breather being replaced.
18th Sep 2014 9:06pm |
Reported to dealer today and booked in for 1 week on Tuesday as earliest date they had a courtesy car
19th Sep 2014 7:29pm |
Car in at garage today. Call late afternoon reporting that they wiped down the saturated components and sourced the leak to a bolt that hadn't been fully tightened on the Front Diff during recent works.
30th Sep 2014 8:04pm |
Nice result, mine is in tomorrow, to see if they can finally sort out the transfer box leak!
30th Sep 2014 9:30pm |
Good luck NMJ!
30th Sep 2014 9:32pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2266 |
Well you can't do more than that to help them hope it all works out and the leak is gone when you get it back |
1st Oct 2014 6:39am |
