Home > Maintenance & Mods (L322) > SC leaking oil - Ladder Frame... Or something |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35415 |
lucky you have a warranty ryan... ... - .- -.
1st Oct 2014 12:47pm |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
Apologies if I'm describing any of the components incorrectly. I've extensively checked Microcat and the Workshop Manual but, for example, I'm still not exactly sure what the aluminium?/ silver box with the X pattern (pictured below and on page 1) is officially called/ please?):
22nd Oct 2014 5:38pm |
Having cleaned the areas off thoroughly last week and having booked the car in to the garage for further assessment and works this Friday, I further inspected the affected areas today and exactly one week on, the visible oil leaks/ deposits prevail.
29th Oct 2014 3:36pm |
Change of plan. Car now booked in for a later date as they anticipate they'll need it for at least 3 days given that it's a recurring oil leak, just in case it's not obvious to source and in case LR warranty decide to send an assessor when they do source it.
30th Oct 2014 6:08pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1778 |
Where in the country are you? I'm in the central belt-ish tomorrow, could have a quick look if you need it |
30th Oct 2014 6:50pm |
Thanks very much for the offer Mikey, just saw your reply. I'm North of England between now and the car going back into the garage.
30th Oct 2014 11:26pm |
So the diagnosis is that the oil leak is because of a failed sump gasket seal.
13th Nov 2014 11:23am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6737 |
More than you can ever imagine, then multiply it by 10 and you'll still be short! Got - 2017 SDV8 Autobiography in Loire Blue
13th Nov 2014 11:33am |
Quoted 20 hours labour? |
13th Nov 2014 11:40am |
Are you sure you didn't mishear and they said 20 minutes? Got - 2017 SDV8 Autobiography in Loire Blue
13th Nov 2014 12:19pm |
Unless that includes time spent to diagnose already?
13th Nov 2014 12:43pm |
It's not what you want to hear, but it's going to be a good few hour work to replace.
13th Nov 2014 1:22pm |
Could this also be connected in any way to why we've been getting old wheelbarrow noise type squeal when the car is driving/ freewheeling in a straight line (the garage says no, that will be purely brakes related as it does stop if I pump the brakes)?
13th Nov 2014 1:55pm |
I wouldn't have thought so, but without hearing the noise, it's difficult to pinpoint |
13th Nov 2014 1:56pm |
