Home > Maintenance & Mods (L322) > SC leaking oil - Ladder Frame... Or something |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
was this gasket something the dealer had already done Ryan?.. ... - .- -.
13th Nov 2014 1:56pm |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
Sump gasket seal diagnosis was reviewed.
21st Nov 2014 5:18pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8275 |
Well that was a result, shame you had to intervene, still, nice and cheap for you.... Pete
21st Nov 2014 6:49pm |
Another justification - for our RR anyway - for investing in the LR extended or some other good warranty (on MD rates, the cost of this claim alone appears to exceed the annual premium).
21st Nov 2014 7:03pm |
you have such a persuasive way with words Ryan, glad its going to be sorted.. ... - .- -.
21st Nov 2014 7:07pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8621 |
Well that is a result, a bit of lightly applied pressure on the warranty provider can sometimes be required, however in LR defence "external oil leaks" are excluded so you did well there! And at least with the engine out they will be able to see the whole engine to assess if this is the only leak......
21st Nov 2014 7:37pm |
@nmj,
21st Nov 2014 7:57pm |
Just got the car back after over 5 weeks in the garage for the engine out and Ladder Frame leak to be fixed.
18th Dec 2014 11:14am |
At least it's back for the cold weather and christmas👍 There is nothing that can't be fixed with a hammer😜😜
18th Dec 2014 5:34pm |
And driving like a tight drum! Velvet!!
18th Dec 2014 7:27pm |
19th Dec 2014 4:56pm |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
Hi pld118
25th Jan 2015 6:36pm |
Now being told that after initial inspection by another workshop they might have identified at least two leaks, the main oil leak being from the front of the engine, possibly behind the timing cover. For that, they need to remove the drive belt, pulleys and timing cover. They say once all that has been removed hopefully they can pinpoint where the engine oil leak is coming from.
18th Apr 2015 6:06am |
Just realised this thread has been ongoing for 7 months to the day
18th Apr 2015 1:18pm |
