![]() | Home > Maintenance & Mods (L322) > Electric deployable sidesteps |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
I'm not to sure on these are they easy to fit/ remove ? |
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 ![]() ![]() ![]() |
no they are not easy to fit there are control modules and programming to deal with ! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
the steps themselves are easy to fit but the wiring loom, ecu and switch are not so easy.. ... - .- -.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
And they are just one more thing to go wrong.
the threaded holes are present on all FF's and if you take your steps off you can just leave the bolts in place.. ... - .- -.
Thanks Stan , not with the car so couldn't see how they're fitted, good to know if I take them off there were no other holes drilled to fit them , thanks |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3866 ![]() ![]() ![]() |
if you do take them off, I need some |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
^different loom on the 2010my Geoff. Though I think the steps themselves are identical. There is nothing that can't be fixed with a hammer😜😜
Loom should be the same just a different ECU |
I'm waiting for Dan, he'll make sure I get the right bits. |
