Home > Maintenance & Mods (L322) > Electric deployable sidesteps
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
I'm not to sure on these are they easy to fit/ remove ?
Post #280040 9th Sep 2014 7:00pm
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
no they are not easy to fit there are control modules and programming to deal with !
Post #280130 10th Sep 2014 8:14am
the steps themselves are easy to fit but the wiring loom, ecu and switch are not so easy.. ... - .- -.
Post #280132 10th Sep 2014 8:38am
And they are just one more thing to go wrong.
I had to replace a bracket and motor on mine cos they sit under the car getting all the abuse of weather, road, salt, water, mud etc (IMO a poor design) and that cost me nearly £600, just to get the step working again. The irony is that I don't use them or need them! Evil or Very Mad Discovery 4 HSE
Post #280140 10th Sep 2014 9:19am
J evro
Yeah to clarify Ialready have them on when I bought the vehicle and they work fine but I'm not sure on them and wondered if they bolt straight on or would have had to have additional holes etc drilled that would be left if removed ?
Post #280741 13th Sep 2014 3:46pm
the threaded holes are present on all FF's and if you take your steps off you can just leave the bolts in place.. ... - .- -.
Post #280744 13th Sep 2014 3:59pm
J evro
Thanks Stan , not with the car so couldn't see how they're fitted, good to know if I take them off there were no other holes drilled to fit them , thanks
Post #280750 13th Sep 2014 4:32pm
supershuttle
if you do take them off, I need some Very Happy Geoff
Post #280793 13th Sep 2014 7:32pm
^different loom on the 2010my Geoff. Though I think the steps themselves are identical. There is nothing that can't be fixed with a hammer😜😜
Post #280884 14th Sep 2014 10:51am
Loom should be the same just a different ECU Thumbs Up
Post #281031 14th Sep 2014 10:08pm
supershuttle
I'm waiting for Dan, he'll make sure I get the right bits. Very Happy Geoff
Post #281046 15th Sep 2014 6:39am
