Home > In Car Electronics (L322) > Rear dash camera fitment
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
After I fitted the front camera with great success ( http://www.fullfatrr.com/forum/topic23389.html )and inspired by cliffy's post (http://www.fullfatrr.com/forum/topic24647.html?highlight=rear+camera) I wanted to fit a rear back up camera but didn't want it just working when in reverse but when moving forward and wanted a camera that recorded, I found this little camera with the AV cable built in to the wiring loom, its the same size as the front 0801 model but with no screen on the camera and cheaper.
Needed to buy the tv loom
link for the tv loom http://www.ebay.co.uk/itm/AV-Video-Audio-I...35cc0d02cc
link for the camera http://www.ebay.co.uk/itm/161078047884?ru=...26_rdc%3D1
Camera spec
Model number - NT-168
lens angle - 140 deg
video format - AVI 1280x720P resolution
frame rate - 30 F/S
micro sd card - 2G - 32G high speed card class 4 and above
So as per my front camera I needed to find another ignition live in the front fuse box, there is NO ingnition live at the rear fuse box, its all positive live, but this was handy for the camera to have the memory stored.
So wiring up the inside the A pillar again and under the head lining, removing door seals, grab handles and the 2 dog guard clips and feed through, missing the air bags, and down the D pillar to where the sat nav area in the rear near side.
Using fuse 42 the vanity mirror to piggy off
No ignition live but useful for the camera memory, wire cable fed through the spare wheel well and fused.
Next was to make a bracket as fitting the camera to the tail gate was an issue ( see the end Whistle )
A piece of 2mm alli strip, shaped and bent to fit snugly
Next take the centre console off, the switch to fit.
Watching the youtube video you don't need to take the hand brake handle off or remove the selector grip off either, why make work for yourself, you only need enough room to feed wires in so didn't see the point.
And look, my FF worth £2.55 more! previous owner lost it Laughing
Next was to find a good place for the switch, thinking where to fit, just under the dsp switch on the centre dash using a similar switch or in the coin tray infront of gear selector, or even near the high/low and HDC switches neither where ideal, as involving to take more to bits and the coin tray way would look wrong, so the switch went here.....
the simple wiring
And the finished camera
the camera is both NTCS and PALL but you need to change the setting on the head unit to NTCS for it to work correctly.
As I didn't need the camera on for all reversing this set up is great for me and you can use it in forward motion for your passengers watching the idiot ( you know the type) behind you!
Picture doesn't show up very well as it the grey day here and I only have a HTC phone camera.
What issue, well after I fitted the camera to the tail gate and shut it the camera recorded everything backwards, numbers where like looking in the mirror and sd card issues, so it went back and got another one! There was a fault with the camera first of Big Cry
SD card was in the camera on both pictures ^ v
the screen was rolling up the every few seconds, card was already formatted and both head unit and camera on NTCS
Edited links for camera, av cable adaptor and wiring diagram If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #280541 12th Sep 2014 10:25am
Interesting write up. Thumbs Up
You could have made life a bit easier by taking a fused supply from the rear fuse board and switching it by a relay from the ignition controlled feed in the rear corner. Would have saved running an ignition controlled feed from the front fuse board.
Do you have a link for the camera? Might have a go at this. Thumbs Up
Post #280542 12th Sep 2014 10:47am
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Nice job WD Thumbs Up ...great cam position...I must move mine as its fixed to the rear glass and gets banged around everytime i close the boot..can't be doing it any good Embarassed GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #280548 12th Sep 2014 11:22am
nice idea on the 'clip' mount... ... - .- -.
Post #280561 12th Sep 2014 12:39pm
Welshdragon
Not wanting to start a new thread on cameras, today I have fitted a rear view camera to the horsebox trailer. So far it looks good on the screen in the RR.
All I did was to tap off the positive and negative supply and using a conector above the trailer hitch for ease of disconnectting.
Pictures help though Wink
Not bad for under £8 Mr. Green If it dont work.......burn it!
Post #353168 19th Oct 2015 6:16pm
i think ill get one of those, £8 for the camera and £5000 for the horse box Shocked Laughing
nice job Mike Thumbs Up ... - .- -.
Post #353173 19th Oct 2015 6:59pm
Zirconblue
If you want to put an ignition live in the boot there should be one in the trailer connector.
you can always 'create' an ignition live from anywhere by using a voltage sensing relay from a generic trailer electrics kit. (It detects when the engine is running from the voltage)
Post #353190 19th Oct 2015 7:57pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
@WD Thanks for sharing ... once I get through my list of preventative maintenance I plan on doing this Very Happy Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #353211 19th Oct 2015 8:57pm
Welshdragon
Went out with my girl today, first time to use the trailer camera since fitted......I must say it works a treat in seeing how she's traveling in the box Mr. Green Mr. Green
And I saw a fellow ffrr forum user too...... you probably spotted me before I thought it was you mate Whistle Laughing Thumbs Up If it dont work.......burn it!
Post #354517 28th Oct 2015 7:09pm
horsey TV Thumbs Up ... - .- -.
Post #354522 28th Oct 2015 7:44pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
@WD stop horsing around!! Rolling with laughter Rolling with laughter 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #354535 28th Oct 2015 8:25pm
Welshdragon
Rolling with laughter Rolling with laughter Rolling with laughter
I'm out again horsing around in the forest! Laughing If it dont work.......burn it!
Post #354537 28th Oct 2015 8:28pm
dand
United Kingdom 2008 Range Rover Vogue SE TDV8 Barolo Black
I can't see that trailer being there furlong.
Post #355883 8th Nov 2015 4:59pm
Chasazim
Australia 2004 Range Rover Vogue 4.4 V8 Epsom Green
Rear mount camera
Hello, thanks for the good write-up, I have done the same and it works well. Here is a question, can you get the radio to work while the screen is showing the idiot behind? The co-pilot wants music while she reports on what is going on behind.
Post #360830 7th Dec 2015 9:29am
Chasazim
Help needed.
Well I thought all was working well but that was parked in the garage Confused When I went to reverse out this morning the rear view disappeared and the message " for your own safety the driver can,t watch TV whilst driving" or words to that effect. The screen only shows the rear view when I am in Park, in reverse or drive nothing just the nanny message, Shocked What have I done wrong? Please advise
Post #361001 8th Dec 2015 4:06am
