![]() | Home > Maintenance & Mods (L322) > ID these parts? Front Rear Drop Link Questions |
[s]Hi, been reading some threads re DIY replacing drop links which supposedly take minutes.
Fronts are easy and do not require removal of wheels. Just put car into off-road height and lock it there. Then depending on side you are doing lock wheel right or left. I used a small bottle jack to take pressure off the bottom of the drop link and that makes it easy to remove.
it does Conor, thank you very much.
Pair of genuine LR front ARB drop links ordered from Duckworth Parts for delivery next week.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
the way you're going you'll be re-building engines by the end of the year... |
Can anyone please clarify correct part descriptions to me?
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 ![]() ![]() |
The lower item is an ARB drop link, or stabilizer bar link. Same thing |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
The upper item is one of the track control arms. It has a bush at the rear that connects to the frame and a hole that connects into a separate ball joint connected to the hub. The Track control arms are 'handed', i.e. one for lhs of vehicle and a different one for rhs of vehicle. If you're thinking of doing these, make sure you get the correct one for the side of the FF you're replacing. The ball joint is universal, i.e. not 'handed'.
Thanks very much for the replies.
