Home > Maintenance & Mods (L322) > ID these parts? Front Rear Drop Link Questions |
[s]Hi, been reading some threads re DIY replacing drop links which supposedly take minutes.
11th Sep 2014 9:04am |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Fronts are easy and do not require removal of wheels. Just put car into off-road height and lock it there. Then depending on side you are doing lock wheel right or left. I used a small bottle jack to take pressure off the bottom of the drop link and that makes it easy to remove.
11th Sep 2014 10:38am |
it does Conor, thank you very much.
11th Sep 2014 11:51am |
11th Sep 2014 1:24pm |
Pair of genuine LR front ARB drop links ordered from Duckworth Parts for delivery next week.
12th Sep 2014 9:14am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35247 |
the way you're going you'll be re-building engines by the end of the year... ... - .- -.
12th Sep 2014 9:43am |
Can anyone please clarify correct part descriptions to me?
16th Sep 2014 10:25am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1740 |
The lower item is an ARB drop link, or stabilizer bar link. Same thing |
16th Sep 2014 10:52am |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
The upper item is one of the track control arms. It has a bush at the rear that connects to the frame and a hole that connects into a separate ball joint connected to the hub. The Track control arms are 'handed', i.e. one for lhs of vehicle and a different one for rhs of vehicle. If you're thinking of doing these, make sure you get the correct one for the side of the FF you're replacing. The ball joint is universal, i.e. not 'handed'.
16th Sep 2014 12:57pm |
Thanks very much for the replies.
16th Sep 2014 2:10pm |
