![]() | Home > Technical (L322) > Help! "Selflevel susp. Inact" |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 ![]() ![]() |
do you mean stuck in off road height? if so looky here,
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Assume you disconnected the caravan to take the tow electrics out of the equation first? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 ![]() ![]() ![]() |
If the system has deactivated and the light is not lit on the adjustment knob, you will not be able to reset it without a diagnostic tool, even if you fix the issue.
tsadpt Member Since: 09 Feb 2011 Location: West Sussex Posts: 176 ![]() ![]() ![]() |
Thanks guys. My pump is relocated out of its clamshell due to LPG... There is a gold come filter I can see that looks very shiny and clean, but does not have a hex nut on it... Does anyone know does the pump have 2 cone filters or just the one? Ie should I get it all out in searc of the right filter?!
Yes Paul, disconnected electrics and unhitched to ensure it wast the caravan causing the problem... |
Just an update... Went in to an independent to be plugged in... Fault codes cleared, problem gone and not able to induce the problem... So perhaps an erroneous sensor signal.... Hey ho... |
