Home > Technical (L322) > Help! "Selflevel susp. Inact"
tsadpt
Guys and girls,
Just leaving to one hoe from my hols, and once I had hitched the tin tent I used offload height to help clear the jockey wheel. When I got in the car to drive off I had the above message and no lights on the suspension controls. The car is high... How can I clear the fault? Tried fuses and disconnecting the battery for a few mins... Any ideas?
Post #278169 30th Aug 2014 12:09pm
do you mean stuck in off road height? if so looky here,
http://www.fullfatrr.com/forum/topic23038.html ... - .- -.
Post #278175 30th Aug 2014 12:36pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Assume you disconnected the caravan to take the tow electrics out of the equation first? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #278177 30th Aug 2014 12:44pm
mjdronfield
If the system has deactivated and the light is not lit on the adjustment knob, you will not be able to reset it without a diagnostic tool, even if you fix the issue.
Worth checking the filter thing in the linked thread above though.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #278180 30th Aug 2014 1:08pm
tsadpt
Thanks guys. My pump is relocated out of its clamshell due to LPG... There is a gold come filter I can see that looks very shiny and clean, but does not have a hex nut on it... Does anyone know does the pump have 2 cone filters or just the one? Ie should I get it all out in searc of the right filter?!
Good advice re needing a reset thanks! Presume that is a stealer job unless anyone has the kit in Sussex or Hampshire I. Exchange for a few beers?
Post #278187 30th Aug 2014 1:34pm
tsadpt
Yes Paul, disconnected electrics and unhitched to ensure it wast the caravan causing the problem...
Post #278188 30th Aug 2014 1:35pm
tsadpt
Just an update... Went in to an independent to be plugged in... Fault codes cleared, problem gone and not able to induce the problem... So perhaps an erroneous sensor signal.... Hey ho...
Post #280169 10th Sep 2014 12:56pm
