Home > Technical (L322) > Deodorising the Air Con.
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Unfortunately I am a smoker. I usually switch off the air con when smoking in the car to prevent smells recirculating. Recently though the air con was boing used on a long journey when me and my friend were smoking all the way. Now there is a slight smell when I turn on the air con.
Where is the best place to spray something to freshen up the system? I am not sure how the air is actually circulated. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #84899 1st Oct 2011 4:13pm
The easiest way is to try a can of ac system cleaner from someone like Halfrauds. Comma Air Conditioning Cleaner is what you need.
Simply a case of running the engine with the ac on maximum, set off the canister in the car (with you outside) and let the ac circulate the contents of the can.
Usually works, but then I don't smoke. Smile
Post #84910 1st Oct 2011 6:07pm
typically known as 'bombing'.... ... - .- -.
Post #84913 1st Oct 2011 6:26pm
EVOeng
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
My main dealer uses Fortron air conditioning treatment.
It can be bought for about £6.00
Post #86228 9th Oct 2011 2:10pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Warning...very old thread resurrection coming!!
My question relates to when the AC is switched off....when it the AC is running, the smell is pleasant, but when its switched off the smell is musty?....would these "bombing products" work or is there a filtre i can change?
ps..i dont smoke, fart /burp excessively or have BO.
Ta.
Pm2 GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #276922 21st Aug 2014 12:31pm
i bombed mine paul cos there was a smell when the ac was off ..its possible that maybe a filter change somewhere will get rid of yours rather than a bomb but it worked for me.... ... - .- -.
Post #276923 21st Aug 2014 12:47pm
paulmoran2
Cheers Stan... Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #276924 21st Aug 2014 1:02pm
EVOeng
I can confirm that the air con treatment worked to remove the musty smell.
Post #276933 21st Aug 2014 2:28pm
paulmoran2
Gents...apart from the Pollen Filter (located under the bonnet just in front /centre of the windscreen) are there any other cabin air filters?
Workshop Manual is 3000+ pages and cant see anything else myself.
Ta
Paul GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #277094 22nd Aug 2014 12:20pm
No Paul, just the one sir Thumbs Up
Post #277099 22nd Aug 2014 12:35pm
paulmoran2
Cheers Craig Bow down GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #277101 22nd Aug 2014 12:41pm
Weegie
My recently acquired L322 had a very slightly damp/musty smell with the a/c switched off. I did an oil service and also changed the pollen filter. So far I have not had the smell come back.
HTH John
GAP iiD BT
Post #277112 22nd Aug 2014 1:39pm
