Home > General > 4.4TDV8 Buying/Owning advise please. |
Colour scheme?
17th Aug 2014 5:58pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16288 |
Stornaway & Black inside... |
17th Aug 2014 6:00pm |
Yes familiar with that scheme very nice too |
17th Aug 2014 6:07pm |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
No real problems.
17th Aug 2014 6:29pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3747 |
No issues with mine at all, had the battery recall done and its been trouble free - even the FBH works without issue. There are several software updates for the reverse camera, the radio and AC fan system - all good though touch wood
17th Aug 2014 6:40pm |
My mind got finally made up by the 8 speed gearbox... Seems so much better than the 6 speeds... |
17th Aug 2014 6:45pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3097 |
Sounds like a lovely car Craig!
17th Aug 2014 6:47pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2567 |
Low battery warning (two dealers failed to remedy), dead starter motor, injector-related hesitation (fixed), very, very occasional hanging on to second(?) gear, corrosion on side window and tailgate trim, foam block in door shut/inner-wing fell off. |
17th Aug 2014 7:02pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 |
craig-meister, do pop down for coffee and show it off to me.. ... - .- -.
17th Aug 2014 8:06pm |
woodchip Member Since: 19 Apr 2012 Location: cumbria Posts: 132 |
Last week mine had 3 new door top surrounds, the black bits, and new tailgate struts due to corrosion a new temp sensor, new rear suspension dampers and a gearbox update all on warranty. This is the second 2 1/2 yr FF iv'e had that needed new dampers/ struts. And the car came back spotless. Result. |
17th Aug 2014 8:21pm |
bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 137 |
My Waranty ends in November. I'm not sure how to check what has been done on Recall oris possibly outstanding. How do I find out ?
18th Aug 2014 7:27am |
ring your dealer and give them your vin number and they should advise you.. ... - .- -.
18th Aug 2014 7:54am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8230 |
The dealer will be more than happy to sort out anything and check for updates/recalls as they get paid direct for it, pop in and ask them to check the car over and see what needs doing, did it with a Lexus a few years back and they found loads to do.... Including a wheel refurb when they found a small bit of corrosion on the inside of one of them.... Pete
18th Aug 2014 7:59am |
When i viewed the car (and before starting) it was saying power save mode (or words to that effect) but started 20mins later without hiccup... Is there a tell tale sign if the battery mod has been done? |
18th Aug 2014 8:00am |
