Home > Maintenance & Mods (L322) > Does Copper Ease (grease) damage rubber?
pld118
Hi,
If copper ease is used to grease lower suspension components is there anything in it that could cause rubber bushes, rubber seals or rubber gaiters to become damaged, such as causing the rubber to swell or otherwise degrade?
Thanks.
Post #276153 17th Aug 2014 1:26pm
ebajema
Mmmm, I wouldn't use a copper based grease in an application like that. I would look at something like Shell Rhodina 2, I have been using it for years on cars and it does super well especially in countries with salt on the roads.
I haven't noticed any issues with rubber. MY 2010 5.0 SC Galway green and sand interior!!
Post #276158 17th Aug 2014 2:55pm
I wouldn't have thought so as copper grease is used on brakes.
Why would you though, when it's really used for high temperature applications?
Post #276161 17th Aug 2014 2:58pm
i would use a silicon based lubricant... ... - .- -.
Post #276162 17th Aug 2014 3:02pm
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Copper ease isn't a lubricant it's an anti seize compound for putting on threads etc before the nut goes on .
Post #276168 17th Aug 2014 3:28pm
SteveyD
England 2003 Range Rover Vogue Td6 Bonatti Grey
yeah im with Stan x2 on the silicon lube. Copper slip / grease is a corrosion inhibitor and not what you want.
Post #276171 17th Aug 2014 3:45pm
pld118
Thanks all.
Was curious. Have read other internet views that copper grease won't causing swelling or any form of damage to rubber and yet have also read that mineral based grease can cause swelling/ damage to rubber if applied (don't know if Comma copper ease is mineral based or not?).
The product I had in mind when making the post was Comma copper ease which is sold as a product that:
"Forms a dense protective coating over metal parts that wont wash or burn off. When applied to the back of brake pads it Helps prevent brake disc squeal."
Additionally though it's sold as being a product that:
"Provides excellent protection for metal parts against seizure, corrosion, heat, rust, acid and water."
And it was that last bit of the product description (e.g. protects against corrosion) that had me interpreting/ wondering that it's possibility not exclusively for use on brakes and that it can indeed serve multi purposes?
Post #276174 17th Aug 2014 4:42pm
One thing copper grease does effect is aluminium, it will eat it's way into it over time, so if you have alloy calipers use brake grease..... Pete
Post #276191 17th Aug 2014 5:33pm
clarkie
England 2005 Range Rover Vogue Td6 Adriatic Blue
Re: Does Copper Ease (grease) damage rubber?
Unnecessary quote removed
It cant do as there are rubber seals around the pistons in your brake callipers,it would have been banned years ago on safety ground otherwise.
Post #276192 17th Aug 2014 5:35pm
pld118
Went into Halfords yesterday. They didn't have the Shell product recommended by a Ebajema although they had a good selection of silicon based sprays etc.
As it seemed to be the only product stating it was designed, amongst other aplications, for bushes I bought this spray:
WD-40 SPECIALIST ANTI FRICTION DRY PTFE LUBRICANT (£4.99).
And then yesterday evening before I could even try this product on the bushes, the brakes started giving some squeal again under light breaking, more indicative to me of it being pad/ caliper related, however the Brembo calipers show no obvious symptoms of seizure and the brakes didn't squeal before the pads and discs were changed. A wee bit frustrating not to be able to eradicate an annoying little quirk.
Post #276484 19th Aug 2014 12:30pm
