![]() | Home > Maintenance & Mods (L322) > Does Copper Ease (grease) damage rubber? |
Mmmm, I wouldn't use a copper based grease in an application like that. I would look at something like Shell Rhodina 2, I have been using it for years on cars and it does super well especially in countries with salt on the roads.
I wouldn't have thought so as copper grease is used on brakes.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
i would use a silicon based lubricant... ... - .- -.
birchyman71 Member Since: 19 Feb 2013 Location: stockton on tees Posts: 147 ![]() ![]() ![]() |
Copper ease isn't a lubricant it's an anti seize compound for putting on threads etc before the nut goes on . |
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 ![]() ![]() ![]() |
yeah im with Stan x2 on the silicon lube. Copper slip / grease is a corrosion inhibitor and not what you want. |
Thanks all.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8554 ![]() ![]() ![]() |
One thing copper grease does effect is aluminium, it will eat it's way into it over time, so if you have alloy calipers use brake grease..... Pete
clarkie Member Since: 26 Aug 2013 Location: leicester Posts: 51 ![]() ![]() ![]() |
Unnecessary quote removed
Went into Halfords yesterday. They didn't have the Shell product recommended by a Ebajema although they had a good selection of silicon based sprays etc.
