Home > Technical (L322) > L322 TDV8 2007 diagnostics, limp home mode |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1745 |
Alternator is all done.from the front. Hardest part of the job is getting the fan off |
15th Aug 2014 5:30am |
Dijit Member Since: 09 Jul 2012 Location: Glasgow Posts: 161 |
Thanks Mikey. You say the front rather than the top or underneath. Are you suggesting taking the front end off? I did consider that might be easier but have never done it. Is the fan a special spanner as on the LR 110s? I assume its a left hand thread?
15th Aug 2014 9:51am |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
On a TDV8 you do need to remove coolant pipes, so draining the coolant is required |
15th Aug 2014 10:33am |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Hi Dijit
15th Aug 2014 6:41pm |
Thanks Andy. Two questions, first what were the symptoms and how did you conclude it was the alternator? I ask as I cannot believe an alternator which has failed yet puts out 14V. Secondly just how bad is it to change?
16th Aug 2014 9:09pm |
One of the bearings failed on my alternator, it was still charging at 14 volts but howled like a banshee, so had to be swapped out before the bearing gave up.
16th Aug 2014 9:34pm |
Andy, again my thanks. AFAIK the bearings are fine in that they are not whining or rumbling.
16th Aug 2014 9:45pm |
I used the instructions on the wiki, link below.
17th Aug 2014 2:14pm |
To answer my own question this is the progress made since posting.
21st Aug 2014 1:16pm |
Ok update and the news is not good.
30th Aug 2014 9:26am |
Having spent hours trawling there are a number of suggestions. One in particular is misaligned steering. Am I right to reject that as with the vehicle stationary in park the faults kick in seconds after starting up?
These are the readings off the JLR system firstly with the fault codes (DTCs) cleared then after the car is started.
30th Aug 2014 1:18pm |
v3mmtrangerover Member Since: 29 Jan 2020 Location: sunderland Posts: 30 |
did you get to the bottom of it having the same issues |
29th Jan 2020 7:04pm |
Yup. First check your battery. Below 12V it won't even crank. Next alternator. Basically you are looking for about 14.4V with the engine idling.
29th Jan 2020 11:22pm |
