![]() | Home > Maintenance & Mods (L322) > new battery ...95ah or 110ah |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35644 ![]() ![]() |
been looking into this RANGEROVER and you are right in recommending the varta ..its got a crank of 920 btw and 110ah which is the most powerful battery you can get for the FFRR..best price i found so far is £119 delivered ..theres also a bosch with the same output.. ... - .- -.
the terminals are the same for the varta and bosch batterys and the size is the same and is a very tight fit like you say ...i would have thought an OE landrover price would be very expensive but i will give them a call to see... ... - .- -.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3787 ![]() ![]() |
get the Varta, the LR one's are crap I've had 2 original LR batteries - they only lasted me 12 months each, The VARTA is the one, slightly bigger but she fits OK, terminal layout is the same, its easier if you also lift the bonnet to access height, we struggled at the tyre depot - it went in just with loads of scraped knuckles - would have been a breeze if we had known the bonnet went all the way up and back!
cheers vogue...putting the bonnet into service mode is [apparently] very easy ...i'm swayed to get a varta type 020 which has a 110 ah and 920 crank which are the best specs i can find ..its the same size battery as i have at the moment so fitting it into the space wont be a problem.. has anyone seen this battery for cheaper than £119 delivered?... ... - .- -.
Varta found it here you go :-
that ones £133 delivered...looks like my price is the best at the moment..i didnt think i could get it cheaper.. ... - .- -.
£119 delivered is a blooming good price - not worth the bother chasing round as I doubt very much you will get it cheaper. You will notice the difference with the pre-heater and cold starting in the winter.
my bad vogue, its the bosch at £119 and the varta at £129....both 5 year warranty. ... - .- -.
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
I would leave both LR and varta well alone. My LR par tis produced by Varta!!
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
How long do batteries last on a FFRR?
thanks for that steve, the standard LR battery on mine is the same size as the bosch type 020 [393x175x190] ,that size of 490x200x260 will not fit in my carrier...also according to the spec ,this bosch does have the correct terminal layout... btw , bosch batterys are re-badged vartas, both made by johnson controls.. ... - .- -. Y. O. L. O. . Last edited by stan on 10th Sep 2010 9:24am. Edited 1 time in total |
mines 5 years old fox and whilst messing about fitting leds and drls it would not start the FFRR..left it for a while and it worked but with winter coming i aint taking the risk.. ... - .- -. Y. O. L. O. . |
steve, good tip re europarts ,they stock the bosch 020 with 110ah and 920 crank and at a price of £117 which is the cheapet i have seen for this type of battery..europarts seem to have branchs all over the place so no worries about collecting or taking back if faulty. ... - .- -.
None of my LR OEM Batteries were made by Varta. The Varta i1 spec battery which we are referring to here is significantly more powerful and slightly larger than the OEM one. The OEM batteries had a 12 month warranty. The Varta Battery has a 5 year warranty not 12 months Before anybody orders a battery based on advice contained in a forum I would check if it is the right fitment as there is likley to be difference between a FFRR petrol and diesel - I am referring to Diesel |
