Home > Other Site Sponsors > New firmware & app release, V3.0, for the IIDTool... |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Just a quick thumbs up for the guys at GAP. Just got a none BT tool but ran into problems after updating to version 3. Email to them today (Saturday) and an email back from them with a fix (new download) within a couple of hours. All sorted and well impressed with the service. Cheers Guys
26th Jul 2014 2:53pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
What additional update software is added to the NON BT IId tool V3 from the 2.7? Any benefit to updating? If it dont work.......burn it!
26th Jul 2014 5:27pm |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 317 |
Just bought the BT version of the IID tool and have turned off the TPMS system - a bit scary, but fun!
5th Aug 2014 6:21pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6730 |
You can aim for zero, but the chances are slim! Got - 2017 SDV8 Autobiography in Loire Blue
5th Aug 2014 6:27pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35366 |
you wont get zero, the tpms will show up as four faults even though you have switched it off, but dont worry about that one.. ... - .- -.
5th Aug 2014 6:40pm |
5th Aug 2014 7:56pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 |
Did anyone ever find an answer to this? My 2004 (MY 2005) recognises my phone, a Samsung Galaxy S4, and pairs without any apparent problem. However, when I make a call it rings but when the other end picks up it immediately disconnects and the message "Call Ended" appears. I have tried re-flashing the ECU using the iiD Tool (BT) but, although it starts the process and indicates 41 minutes duration, after about a minute or less it says that the re-flash has failed. I have tried a couple of times but still no joy and I also have had the E05 message showing. Anyone any ideas or pointers, please? John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
27th Aug 2014 1:57pm |
For the Faultmate, they recommend to put a battery charger on the car while doing a re-flash to ensure that the voltage stays high and constant. Maybe worth giving that a try if you haven't done that yet. MY 2010 5.0 SC Galway green and sand interior!!
27th Aug 2014 2:11pm |
Thanks for that. GAP also recommend the same but say that, if the battery has a good charge, it wouldn't be necessary.
27th Aug 2014 2:21pm |
An update. Contacted GAP support and Patrick, once again, came good. Downloaded Beta firmware and Tel ECU Flash worked a treat. Recognises my Samsung S4 GT-19505 and full access to the phonebook.
28th Aug 2014 6:24pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
just updated my one but still sitting at 2.17 V8 facelift Range Rover Autobiography 22" wheels.
28th Aug 2014 8:17pm |
clarkie Member Since: 26 Aug 2013 Location: leicester Posts: 51 |
Daveo, same here but i have the non bluetooth version.the question has been ask a few time when the non bt units are going to be upgraded and has been ignored by the gap people on here. even if the answer is its not going to be done. |
31st Aug 2014 11:10am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
The update for none BT units is out for Beta users so not long now . 2008 MY Supercharged
31st Aug 2014 11:13am |
thanks for the info axle.thats more than has been said by the gap bods |
1st Sep 2014 5:41pm |
