Home > Technical (L322) > Suspension fault |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
What was the specific fault (found with diagnostics), as opposed to the "bong" fault of "AIR SUSP INACTIVE" ?
27th Jul 2014 2:11pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
^as above... Sounds like a height sensor... Should be detectable on diagnostics |
27th Jul 2014 11:24pm |
JAMIE_M Member Since: 01 Apr 2014 Location: South Wales Posts: 9 |
Thank you both.. Given the circumstances leading up to the failure, I agree. Its with a local indie who has looked after the car for the last 4 years, and I don't mind that he's replaced the drier. I think though, I'l invest in my own diagnostics, because that way I could reply to your specific question about which code. I live near the Bearmach store (well within 30 mins) would that be a good diag tool, or would you recommend another one?
28th Jul 2014 2:48pm |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
General concesus on here seems to be to go for the IID tool. 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!) |
28th Jul 2014 2:50pm |
87RJD Member Since: 01 Dec 2013 Location: Wokingham Posts: 103 |
go for iiD |
28th Jul 2014 3:26pm |
OK.... have emailed Dan at DW for a price on the IID tool... also for info.. had a great email dialogue with the guys at GAP.. waiting for a price (Dans on hols I think) and then we'll be GAP'd to the hilt!
1st Aug 2014 8:15am |
No, that shouldn't spring a fault. I have my rear one tied up without a problem (having lost the tiny clip on the gravel ). YMMV.
1st Aug 2014 2:49pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Both my brake pad wear sensors are broken and not connected, I get a "check brake pads" message on the dash but I don't have a suspension error showing, so don't think the pad sensor alone will do it, they may have pulled out or damaged the ABS wires and that would do it.... Pete
1st Aug 2014 6:04pm |
