Home > Maintenance & Mods (L322) > Should I be worried?
At around 70mph in top gear, which is probably around that rev range.............. Got - 2017 SDV8 Autobiography in Loire Blue
Post #273807 31st Jul 2014 3:10pm
Mikey
Hopefully not a broken manifold stud.
You should hear it when revving the car at idle
Post #273820 31st Jul 2014 7:33pm
No nothing at idle and only when it's raining? Question Got - 2017 SDV8 Autobiography in Loire Blue
Post #273823 31st Jul 2014 8:04pm
Just had the call.......................BURST HOSE!!!! YIPEEEE!!
Smile Got - 2017 SDV8 Autobiography in Loire Blue
Post #273910 1st Aug 2014 11:09am
pld118
Laughing
Every day a minefield!
Wink
Post #273940 1st Aug 2014 4:06pm
Googsy
I was right then Thumbs Up for reward I want your brown steering wheel Laughing glad you got sorted Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #273947 1st Aug 2014 5:53pm
It'll be black again very soon, cheeky b'stid! Very Happy Got - 2017 SDV8 Autobiography in Loire Blue
Post #273952 1st Aug 2014 6:13pm
Just go the bongs on the a29 in france, suspect it is probably the turbo hoses.......
Bong....engine system fault......no power, like there is no boost, Pull over, off on again, ok for 20 mins......bong!
Ok then for 3 hours and made it to Calais, bit of black smoke on kick down and going up hills with the tin tent on the back, but otherwise sat at 60 all the way..
Hopeful it is either the hoses or bad fuel from the carrefour! There is nothing that can't be fixed with a hammer😜😜
Post #274028 2nd Aug 2014 2:31pm
Exactly the same symptoms as mine. Hope is the same cause! Thumbs Up
And the fluttering noise has gone too! Smile Got - 2017 SDV8 Autobiography in Loire Blue
Post #274051 2nd Aug 2014 6:40pm
Yep!
Had a look last night when I got back to Dover campsite. 2" split under the webbing.... Shocked on right hand hose as you face the car. For info, insulation tape doesn't work particularly well, can't handle much boost, as my first go at a temp repair revealed.
Off to halfords in Folkestone this morning to get http://www.halfords.com/motoring/paints-bo...pe-25mmx3m to affect a temporary repair to get us home without having to stop and reset every 20mins...... Big Cry eventually found you could just put it in neutral and click the gin back one click and on again and it would reset fine (not a great idea but with a ferry to catch better than stopping) There is nothing that can't be fixed with a hammer😜😜
Post #274088 3rd Aug 2014 7:32am
The Harris tape works a treat! 3 layers of reinforced tape, so far done 120 miles with normal driving and no bongs!
Worth having some in reserve in the boot just in case if you have a tdv8 which hasnt had the top hoses done. There is nothing that can't be fixed with a hammer😜😜
Post #274120 3rd Aug 2014 1:23pm
We don't condone G&T whilst driving sir!!! Laughing Laughing Laughing
Post #274123 3rd Aug 2014 1:37pm
ah yes that could have been my problem there.......... Banging Head
was going for ignition.......... There is nothing that can't be fixed with a hammer😜😜
Post #274136 3rd Aug 2014 5:27pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
G&T sounds better Thumbs Up
Better for your health Thumbs Up Thumbs Up
& you can always get SWMBO to drive Whistle Rolling with laughter 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #274164 3rd Aug 2014 8:52pm
You've not seen swmbos driving Whistle There is nothing that can't be fixed with a hammer😜😜
Post #274177 3rd Aug 2014 9:51pm
