![]() | Home > Maintenance & Mods (L322) > Should I be worried? |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 ![]() ![]() |
Hopefully not a broken manifold stud.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6741 ![]() ![]() ![]() |
No nothing at idle and only when it's raining? |
Just had the call.......................BURST HOSE!!!! YIPEEEE!!
I was right then |
It'll be black again very soon, cheeky b'stid! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Just go the bongs on the a29 in france, suspect it is probably the turbo hoses.......
Exactly the same symptoms as mine. Hope is the same cause! |
Yep!
The Harris tape works a treat! 3 layers of reinforced tape, so far done 120 miles with normal driving and no bongs!
We don't condone G&T whilst driving sir!!! ![]() ![]() ![]() |
ah yes that could have been my problem there.......... |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
G&T sounds better |
You've not seen swmbos driving |
