![]() | Home > Maintenance & Mods (L322) > Should I be worried? |
Maybe the particle filter is glogged up due to lot of town driving ?? Or a turbo hose has split, seems to happen from time to time. MY 2010 5.0 SC Galway green and sand interior!!
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6741 ![]() ![]() ![]() |
I did think that Eugene, as my dear wife has been using it lately for a lot of stop/start driving.
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
P023D, something to do with your turbo, P0480 low speed cooling fan - if you google these (as I have just done), there is quite a lot of info, a good thread on RRsport leading to Disco 3 with a few things you can check.
Turbo hose? Present :2008 TDV8 HSE
I did find some details about these kind of codes. Most pointed to a MAP (or was that a typo and should be MAF) sensor, getting clogged up.
Well I've stocked up on a family sized tub of KY in preparation for the verdict on this tomorrow |
It may not be a typo. The MAF (Mass Air Flow) sensor sits just behind the air filter, measuring the amount of air flowing in. The MAP measures the pressure in the inlet manifold and is a lot harder to reach (well on the SC models, it is fitted on the firewall side of the engine).
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1784 ![]() ![]() |
An 08MY shouldn't have a DPF, so my money is on a split turbo hose |
JAMIE_M Member Since: 01 Apr 2014 Location: South Wales Posts: 9 ![]() ![]() |
Spooky - Ive just posted the on this very subject on another forum on here. Had precisely the same occurrence a few weeks ago - but mine had not been start stop it had just ferried us 350 miles in luxury. But Day 1 same bing-bong and rectification as you describe. By day 2 and 3 I could predict the precise place on a hill it would happen. Met up with my indie, engine cover off - n/s bank, split you could put three finger in hiding behind the mesh. I had some other work done; new discs and pads up front, and new wiper blades all up = £380, which makes me think that the hose and fitting was about £60+£40 hope you find this is your problem |
My fingers and wallet are crossed that it's a hose! |
Not an expert, however having seen the sub 45 second it took for the indie to find the problem, here's what he did should you choose to try it.
I'm 500 miles away from where the cars going in, but it's in good hands.
Cant say I did... and the hoses are on the top of the engine.. I |
A "fluttering" noise at anything under 2500-3000rpm? |
