Home > Maintenance & Mods (L322) > Fitted a Snorkel
Fitted a Snorkel
After drowning the Rangie on it's last outing a snorkel then became top of the list of mods, no one makes one that I can find and after fitting one I can understand why, there is not a lot of room.....
I had a look at a mates Disco 3/4 and the rake of the windscreen and the clamshell bonnet are virtually the same as the L322 and it looked like a snorkel for a Disco would fit with some mods, managed to find one from a guy on another forum who bought it to fit his P38 but sold the car before he got round to it, a small donation to his beer fund and I had the starting point, it had never been fitted but did have some parts missing...
First job was to remove the wing and take a look at the space available, not much is the answer. The Disco, being on a chassis doesn't need such strong inner wings but the L322 has a lot of strength here and the gap between inner and outer wing is much less. The good thing is the original intake from the wing into the airbox and on into the engine is pretty well sealed, there are rubber "O" rings on the joints to the airbox, the box itself is pretty water tight, as are the joints to get to the inlet manifold, certainly good enough for the type of wading it will be doing, if you were going to try some Camel Trophy type wading with your head out the window just above the water level then it may need more work, mind you so would everything else on the car......
Inner wing with air intake
You can see here the limited space, the plastic wheelarch cover shows how close the outer wing is to the inner wing
Next job was to make an elbow to take the inlet back to the snorkel, the hole in the inner wing is around 3" diameter, but a 3" hose wont fit inside the inner wing so I made up an elbow that used the entire space available, the outer wing reduces in size from bottom to top and from front to back, I made this to accept a 4" intake pipe that is squashed to an oval inside the wing and I was hoping would allow enough airflow.
First rough mockup
Then some cleaning up and filler work, a quick check on fitment, it has to fit within the inner wheel arch plastic trim and it just does
Finish it off to a standard that is easy to take a mold from
Then take a mold off it to produce the final elbow, I didn't want to use the buck as it had got rather thick to get the correct shape and was made from plastic, filler and fiberglass....
Then made the final elbow, doesn't have to be as polished as the buck....
It has to be this weird shape to maximise the airflow
Fitted to the car
Then fit the snorkel to the front wing, out with the drill and jigsaw....
I had to enlarge the hole to aid fitting as it's so tight and forgot to take a pic of it, just maximised the size out to the fitting holes...
Also fitted the grill and cut this as well....
Then fitted the new elbow with the air inlet pipe, this is two layered silicon hose with a metal spiral so holds it's shape and is bendable.. Used Tiger seal to attach and seal the elbow to the inner wing
Then refitted the wing, pulled the pipe through the hole and fitted it to the snorkel, then had fun trying to get behind the wing to bolt the snorkel to the wing with the pipe in the way, was rather fiddly but managed it in the end.
Had to make a bracket to fit the top of the snorkel to the "A" pillar, it was missing, made it go underneath the "A" pillar trim so as to keep the door seal working as it should. Cut a small slot in the trim to fit it...
And that was the fitting finished.... then on to the aesthetics, not that they look that nice anyway, more function than form but this one had "Discovery 3" on it and it looked a bit funny with half the "so called" air intake vents poking out from underneath...
So to neaten it up I ground off the logo
Went over it with the D.A. sander
Also sanded off the awful plastic flash line it had all the way down the front...
Then plastic primed it and painted it with truckbed liner, hopefully it will last, moved the side repeater to the cut out (this is for the wheel arch on a Disco) and painted the side vents body colour which I think looks better....
Painted the other side vents as well...
The finish looks better than standard but this is one of those cheap Chinese copies..
It takes some abuse off road and gets smacked a lot but is very robust...
I had done some testing of the short term fuel trims before fitting it all so had something to compare with to see if the airflow was restricted, at 70mph they are between 1-2% higher so this would indicate it's getting a ram air effect at this speed and is in fact getting more air in, there is no noticeable drop in performance in acceleration. I fitted the innards of it all whilst visiting my Mother during the week as my brother was around to help with an extra pair of hands and it is about 220miles from where I live... It used slightly less fuel coming home than it did going so I think the airflow is fine.... If you cover the top of the snorkel it sucks in the pipework and stalls the engine so it appears to work well.... Off to the Lake District in September and there are some decent river crossings there so that will be the test....
Rocksliders next.... Pete
Post #273094 27th Jul 2014 6:19pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Love it Thumbs Up Great job....some photos of the "wade depth testing" will be coming soon then?? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #273102 27th Jul 2014 6:47pm
nestu
Job well done Thumbs Up Looks great too Very Happy
Post #273120 27th Jul 2014 7:57pm
RR2008HSE
I'm impressed. Thumbs Up Nice, clear write up too.
Post #273122 27th Jul 2014 8:12pm
Spectacular modification, very brave to cut into the wing! and some lovely glass fibre work.
Not sure I like the look, but this one is all about function, yes Thumbs Up as hats off to you for where you take your FFRR, a far braver man than me! .
Post #273133 27th Jul 2014 8:42pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Tidy job there, well done good write up too Thumbs Up
Just hope you have sealed up all connections well, would be very Embarassed in some deep water if all went wrong and a kitted 90 winched you out Laughing If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #273136 27th Jul 2014 8:55pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Fantastic job, great skills Thumbs Up 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #273139 27th Jul 2014 9:02pm
n1cktdv8
Never ceases to amaze me the lengths that peeps go too...this is a fine example of that and you should be very pleased with yourself mate
Bow down Is this where I put the car details and a bit about myself ?........
Post #273143 27th Jul 2014 9:25pm
Thanks for the comments guys, I am pretty pleased with it but can't say I really like the look of them, does spoil the lines of it a bit.... Pete
Post #273146 27th Jul 2014 9:53pm
RR2008HSE
^ I think it depends on the car. It may be a bit"different" on a stock FFRR, but if you throw on some off-road tyres, a winch, sliders, and roof rack with ladder and I think it would fit in perfectly. Thumbs Up
And just about perfect with a Tangiers Orange respray. Thumbs Up
Post #273188 28th Jul 2014 7:30am
Great job !! Thumbs Up Bow down All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #273194 28th Jul 2014 8:28am
Bagus
United Kingdom 2016 Range Rover Autobiography 5.0 SC V8 Loire Blue
Well impressed. Looks a top job Thumbs Up
Post #273228 28th Jul 2014 12:42pm
Looks fantastic!!
You ran into the same issue as me, nowhere was interested in making one other than a bespoke unit for a 4 figure sum!
Interesting you used the D3 unit as I was looking at using one from a P38 or XJ jeep so it would run along the wing.
What have you done about the elbow and airbox inside as thats not water tight from the wing to the inlet? Also the Axle breathers come up in the engine bay so these could get plumbed into the post airfilter but pre turbo pipework to keep them only using clean air.
The next big thing you have to do if you haven't already is seal the cabin supply box up. Dont faff around too much with this as i found spending 10minutes taking it off and cover the firewall/bulkhead tubes was the easiest method.
The doors and stuff you should fine are fine as they are double sealed but remove the seals if they look even slightly funny and feed them rubber feed like the gummi phelge stuff reccomended on here somewhere to keep them soft! i've had water up the side windows on the passenger side and coming over the windscreen on a water crossing before and not suffered from it due to the engines air pocket and the water height dropping massively on the drivers side so it was well under the wing intake Smile
Glad to see some more MTR's being used in anger! If they ever wear out look to get the Scorpion ATR tyres as they are getting great ratings on the disco forum and dont suffer like the MTR's do when used on the road in wet weather Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #273240 28th Jul 2014 1:49pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Now that is an impressive install! I can certainly appreciate how much effort has gone into that and it makes it look like a factory kit too.
Out of interest what else are going to do prep wise for wading? The amount of electrics would worry me plus the aging door seals! Incidentally I came across 'CorrosionX' for another project which is used in the US military on aircraft for corrosion protection with having the adding benefit of making electrical connections water resistant. It's like a thick WD40 but with high di-electric strength so even circuit boards can be coated in the stuff. Might be worth spraying your electrics with some.
Post #273268 28th Jul 2014 4:38pm
Important bits are usually in water tight boxes. The alternator could do with a good coating of something as they are pretty exposed. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #273270 28th Jul 2014 4:47pm
