![]() | Home > Maintenance & Mods (L322) > Fitted a Snorkel |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
Thanks for your thoughts, all gratefully received, always good to get different pair of eyes on an issue and another point of view A custom built one would be a fortune I guess Don't know if the diesel is different but the pipe from the wing to the airbox is pretty well sealed on mine, there are two inner wings and the pipe between them is totally sealed, the pipe then goes down round a bend and back up to the airbox, the join to the airbox has a rubber "O" ring on it, so thats sealed as well, the airbox top has another "O" ring and is sealed, the MAF is just a tight fit and I will look at doing something there but when you cover the top of the snorklel it actually pulls it tighter and there will be minimal water getting in. the airpipe to inlet manifold has a rubber seal and seems to be well sealed. There is another pipe from the airbox to what I believe is some sort of petrol vapour breather and that is sealed to the airbox, there is a drain in the bottom of the airbox to let water out with a little one way valve and I've cleaned that out and made sure it works OK. I know it won't be totally watertight but I think it will be enough for the type of wading you get whilst greenlaning... Didn't like the look of the ones that come right along the wing and the rake of the screen is different and they don't allow for the bonnet to open as their too tight to the bodywork... the Disco one seamed the best option...
Do you mean the heater intake, I was going to cut a piece of rubber matting, open the bonnet, lay it over the intake and then shut the bonnet to trap it in place and stop water getting in. I will check all the seals, I know the drivers door one is worn a bit but it's quite high up so shouldn't be too much bother, they did hold the water back for several minutes when we were stuck in the river.
They seem pretty good to me in the wet but I don't drive it too fast, I do like the look of the Scorpians so they will be contenders I am enjoying this pioneering work, won't get it right first time every time but hopefully over a period of time I'll get there... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286
Brilliant good job |
Thanks for the praise.... glad you think it looks "factory" The sensitive bit of electrics is the BECM which lives under the passenger seat, this is covered in lacquer, was under water in mine and didn't seem to mind.... The ICE units in the boot died.... The suspension pump is clever enough to pump water and not worry and is working fine after a good clean and dry. Door seals lasted for some time, I think most of the water came in through other areas, where the handbrake cables go through the floor look favorite... the boot filled up due to the monkey who fitted the LPG tank, looks like the holes in the floor were made with a blunt hammer!!!! and they let it pour in..... Off to look at CorrosionX now, thanks for the heads up.... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
| sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613
Very impressive work |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
The big inlets in the boot area are the breathers either side of the boot. you can seal them as they are just plastic cartridges so can be pulled out and a blanking plate made and glued in place using windscreen adhesive.
Can I come and borrow it.... plan 2 was to take the outer wing off, spray everything with wd40, put the wing back on and fill the entire area with expanding form, then take the wing off, foam falls out, sand 5mm off the foam all round and make a perfect fit size intake and doing it in KF would be fun.... That stuff does look good but I'm not a great fan of sealing things up totally, found in the past that you then get condensation build up inside which leads to more problems. Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
Cheers, I'll have an explore.... Going to junk the head unit and all the original ICE and use one of those Chinese all in ones so that will get rid of the problem anyway....Might then have enough room to mount the suspension pump high in that rear wing and keep it out of any more trouble... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
The pump would be fine fully submerged if the seal is still place correctly, you just need to raise the intake for it |
Hi,
| TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848
You two do know you're allowed to drive around water right? |
BORING^^^^
That would be just boring..... water is for splashing in..... __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
| john24 Member Since: 23 Dec 2023 Location: Wakefield Posts: 4
looking to do the same do you have the molded for it how did take to fiit once the mould was done what size of pipe did you use, only in ossett m1,j40 not to far email 24paper24@gmail.com yours john holland |
That was 10 years ago!!!!! I don't have the ability to make another elbow you would have to do it yourself...
