![]() | Home > Maintenance & Mods (L322) > Fitted a Snorkel |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8518 ![]() ![]() ![]() |
After drowning the Rangie on it's last outing a snorkel then became top of the list of mods, no one makes one that I can find and after fitting one I can understand why, there is not a lot of room.....
You can see here the limited space, the plastic wheelarch cover shows how close the outer wing is to the inner wing
Next job was to make an elbow to take the inlet back to the snorkel, the hole in the inner wing is around 3" diameter, but a 3" hose wont fit inside the inner wing so I made up an elbow that used the entire space available, the outer wing reduces in size from bottom to top and from front to back, I made this to accept a 4" intake pipe that is squashed to an oval inside the wing and I was hoping would allow enough airflow. First rough mockup
Then some cleaning up and filler work, a quick check on fitment, it has to fit within the inner wheel arch plastic trim and it just does
Finish it off to a standard that is easy to take a mold from
Then take a mold off it to produce the final elbow, I didn't want to use the buck as it had got rather thick to get the correct shape and was made from plastic, filler and fiberglass....
Then made the final elbow, doesn't have to be as polished as the buck....
It has to be this weird shape to maximise the airflow
Fitted to the car
Then fit the snorkel to the front wing, out with the drill and jigsaw....
I had to enlarge the hole to aid fitting as it's so tight and forgot to take a pic of it, just maximised the size out to the fitting holes... Also fitted the grill and cut this as well....
Then fitted the new elbow with the air inlet pipe, this is two layered silicon hose with a metal spiral so holds it's shape and is bendable.. Used Tiger seal to attach and seal the elbow to the inner wing
Then refitted the wing, pulled the pipe through the hole and fitted it to the snorkel, then had fun trying to get behind the wing to bolt the snorkel to the wing with the pipe in the way, was rather fiddly but managed it in the end. Had to make a bracket to fit the top of the snorkel to the "A" pillar, it was missing, made it go underneath the "A" pillar trim so as to keep the door seal working as it should. Cut a small slot in the trim to fit it...
And that was the fitting finished.... then on to the aesthetics, not that they look that nice anyway, more function than form but this one had "Discovery 3" on it and it looked a bit funny with half the "so called" air intake vents poking out from underneath...
So to neaten it up I ground off the logo
Went over it with the D.A. sander
Also sanded off the awful plastic flash line it had all the way down the front...
Then plastic primed it and painted it with truckbed liner, hopefully it will last, moved the side repeater to the cut out (this is for the wheel arch on a Disco) and painted the side vents body colour which I think looks better....
Painted the other side vents as well... The finish looks better than standard but this is one of those cheap Chinese copies..
It takes some abuse off road and gets smacked a lot but is very robust...
I had done some testing of the short term fuel trims before fitting it all so had something to compare with to see if the airflow was restricted, at 70mph they are between 1-2% higher so this would indicate it's getting a ram air effect at this speed and is in fact getting more air in, there is no noticeable drop in performance in acceleration. I fitted the innards of it all whilst visiting my Mother during the week as my brother was around to help with an extra pair of hands and it is about 220miles from where I live... It used slightly less fuel coming home than it did going so I think the airflow is fine.... If you cover the top of the snorkel it sucks in the pipework and stalls the engine so it appears to work well.... Off to the Lake District in September and there are some decent river crossings there so that will be the test.... Rocksliders next.... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- Last edited by Haylands on 4th Jun 2022 10:29am. Edited 1 time in total |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Love it |
nestu Member Since: 17 Nov 2013 Location: Lancashire Posts: 11 ![]() ![]() |
Job well done |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
I'm impressed. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Spectacular modification, very brave to cut into the wing! and some lovely glass fibre work.
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Fantastic job, great skills |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Never ceases to amaze me the lengths that peeps go too...this is a fine example of that and you should be very pleased with yourself mate
Thanks for the comments guys, I am pretty pleased with it but can't say I really like the look of them, does spoil the lines of it a bit.... Pete
^ I think it depends on the car. It may be a bit"different" on a stock FFRR, but if you throw on some off-road tyres, a winch, sliders, and roof rack with ladder and I think it would fit in perfectly. |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
Great job !! |
Bagus Member Since: 15 Apr 2014 Location: London Posts: 202 ![]() ![]() ![]() |
Well impressed. Looks a top job |
Looks fantastic!!
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
Now that is an impressive install! I can certainly appreciate how much effort has gone into that and it makes it look like a factory kit too.
Important bits are usually in water tight boxes. The alternator could do with a good coating of something as they are pretty exposed. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
