![]() | Home > Other Site Sponsors > New firmware & app release, V3.0, for the IIDTool... |
E4 GUY Member Since: 07 Jan 2013 Location: London Posts: 513 ![]() ![]() ![]() |
I'm going to try when I get home
Amazing Support from Patrick at GAP
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Hi Patrick, any news on the update for the non Bt tool?
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 ![]() ![]() ![]() |
what about the need to enter the code each time, has that been removed also? 2007 TDV8 Vogue SE Java Black |
Yes. !!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 ![]() ![]() |
i wonder how much a dealer would charge for that.... |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 ![]() ![]() ![]() |
Now, how about an idea - since the IID tool can record live data, how about an extension to the IID app to do some form of 'health monitoring', which is commonly used in the aircraft industry (and plenty others no doubt). One could define say 20 key parameters - i.e. engine oil temp and pressure, coolant temp, fuel pressure, etc etc - and every so often (1,000 miles) you could plug your IID tool in and it would record snapshot values of each parameter, possibly averaged in an intelligent way. The app could then produce a standard report showing the trend of these parameters against mileage, allowing early recognition of an adverse trend i.e. slight drop in oil pressure? |
87RJD Member Since: 01 Dec 2013 Location: Wokingham Posts: 103 ![]() ![]() ![]() |
Hi all
re upgrade, go back a few posts.. ... - .- -.
OK Stan, so I see others have done it, I'll re word my question, has anyone else had E5 error message while doing the upgrade to the BT ECU, if you have, what did it mean?
Completed BT upgrade to after getting support from Patrick at GaP. There has been a little modification to the latest software in the last few days (Quote from Patrick) so if you updated your IID tool more than a few days ago it would be worth downloading the latest version if you get an error message while trying to update your BT unit.
PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153 ![]() ![]() ![]() |
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 506 ![]() ![]() ![]() |
Patrick, emailed your support but thought I'd try here if quicker. What setting do I need to put the car in when storing and shipping in a container and where can I find it on the menu?
