Home > Maintenance & Mods (L322) > Preventative maintenance - top ten?
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
I've had my FFRR (2008MY 3.6 TDV8 VSE) for coming up to a year, and it's been brilliant - the best car I've owned by miles. I like maintaining my stuff properly, so, in addition to having the car serviced as per the LR FFRR service schedule and fixing defects when they arise, does anyone have any suggestions for what should be on a preventative maintenance 'top ten' list?
Here's what I've come up with so far:
1. Keep it in a garage when not in use
2. Regular wash/clay/compound/wax to protect paint
3. Intermediate engine oil/filter change between service intervals
4. Gearbox oil megaflush change (interval?)
5. Clean mud from rear wheel arches, repaint/reseal as necessary
6. Leave engine to idle for 30sec before shutting down to cool turbos
7. Change diff and transfer box oils (intervals?)
8. ?
9. ?
10. ?
Cheers, fanders
Post #270870 14th Jul 2014 8:31pm
Vorbis
United Kingdom 2007 Range Rover Vogue SE TDV8 Santorini Black
8. Make sure you change valves with each new set of tyres to avoid corrosion and looking like a prat on an esso forecourt
Post #270878 14th Jul 2014 8:44pm
Vorbis
I'm not bitter honest Laughing
Post #270879 14th Jul 2014 8:47pm
check and replace as necessary, wheel nuts. They swell and you can't get the wheels off without a socket, hammer and long brace.
periodically check that the rear pads are free to move in the rear calliper/pad carriers, otherwise they will seize and cause the rear brake to overheat. There is nothing that can't be fixed with a hammer😜😜
Post #270880 14th Jul 2014 8:49pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Ref 4. Do not MegaFlush. Ever! 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #270887 14th Jul 2014 9:06pm
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Buy a CTEK and charge battery on a fairly regular basis Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #270893 14th Jul 2014 9:33pm
Replace locking wheel nuts with standard nuts. 2008 MY Supercharged
Post #270918 15th Jul 2014 2:30am
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
If keeping towball in place (to stop people getting too close behind at junctions) then remove and replace in socket regularly to prevent seizing. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #270920 15th Jul 2014 3:36am
pld118
@Axle, why replace locking nuts with standard nuts?
Thanks
Post #270931 15th Jul 2014 6:54am
Because they are a pain in the butt and any one who has the ability to jack you 3 ton car will also have a universal locking nut remover . 2008 MY Supercharged
Post #270978 15th Jul 2014 9:33am
Why not do a gearbox mega flush? Got - 2017 SDV8 Autobiography in Loire Blue
Post #270980 15th Jul 2014 9:38am
^ I'm interested to know that as well. Thumbs Up
Post #270988 15th Jul 2014 11:24am
Is it because they don't change the filter?
Post #270989 15th Jul 2014 11:34am
verydisco
^^^are you serious ??? l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #270990 15th Jul 2014 11:43am
What do you now that we don't? Got - 2017 SDV8 Autobiography in Loire Blue
Post #270995 15th Jul 2014 12:11pm
