![]() | Home > Maintenance & Mods (L322) > Preventative maintenance - top ten? |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
If you mean me then here's the thread. |
I think this is true of all gearboxes. This 'sealed for life' thing seems a false economy. |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
impressive...
When they say "Sealed for life" what they actually mean is "Sealed for the life of the warranty" ![]() |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8687 ![]() ![]() ![]() |
ZF and land rover now recommend service at 100,000 if used lightly or 60,000 if used for towing on the 6hp26. |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 ![]() ![]() ![]() |
Thanks for the input chaps, I have some ideas now, hopefully others will find it useful:
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 ![]() ![]() ![]() |
While cleaning rear arches of mud,get the rims off and clean out the rear subframe properly and coat with waxoyl if you can and if you have the time,coat your brake lines with lithium grease to keep corrosion at bay |
I would add keep an eye on the boot lid lip as its prone to rust and if starting treat it asap. |
