Home > General > No Drive
Page 1 of 3 123>
liverpoolphil
United Kingdom 2003 Range Rover HSE Td6 Tonga Green
No Drive
Hi All
2002 TD6 HSE, 110k miles, full dealer history, not missed a beat in the 12 months owned, not driven hard (couldnt if you tried )
Pulled out of petrol station this morning on way to work and lost all drive. Managed to roll the car to a parking spot and cut out engine straight away. Left for a couple of minutes, started it up fine but when I select any gear, its make some pretty bad noises (clunking, whining) and will not drive at all. Nothing displayed in message centre
Spent this morning researching and found it may be one of a few different things (box, diff, torque convertor etc)
Any thoughts, ideas, experiences shared will be appreciated
liverpoolphil
Post #26639 28th Aug 2010 10:17am
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Has it had the prop shaft recall / enhancement (according to our local service manager).
Post #26641 28th Aug 2010 10:41am
RRV
United Kingdom 2015 Range Rover Vogue TDV6 Santorini Black
100% Diff/shaft mate......should be covered under LR recalls. Confused If you have nothing nice to say,say nothing at all.
Post #26643 28th Aug 2010 11:11am
liverpoolphil
it has definitely had the diff done as I checked the history out with the main dealer before buying
If its been done once before, whats the score if it goes again?
Post #26644 28th Aug 2010 12:02pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
IIRC there is a small plastic linkage in the shifter mechanism, I wonder if it has given up the will to live? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #26646 28th Aug 2010 12:14pm
Pauld
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
Front Diff. it may have been replaced in the past:-
However only relatively recently (18 ish months) did they develop a replacement that worked. If this is the case Land Rover should repair FOC.
Alternatively it could be the gearbox giving up Big Cry Big Cry
Post #26647 28th Aug 2010 12:14pm
RRV
Yes as above.....mine on my old TD6 was replaced then about 18 months ago had a recall for a "newer" fix FOC. Thumbs Up
Get on the blower and Im sure it will be covered mate Cool If you have nothing nice to say,say nothing at all.
Post #26648 28th Aug 2010 12:26pm
RRV
Oh yes and when they did the recall they refunded all the money I had paid the first time it was replaced so I was very happy about that too Thumbs Up Bow down If you have nothing nice to say,say nothing at all.
Post #26649 28th Aug 2010 12:28pm
liverpoolphil
thanks for the help fellas, so its definitely the diff? Should I get it check by the indy before getting on the phone?
Bow down Bow down Bow down
Post #26651 28th Aug 2010 1:36pm
Pauld
or gearbox....
If Land Rover play silly Censored and do not do the work under warranty, speak to Ashcroft transmissions. They do a repair kit, i think, that is a fraction of the price of a new diff. Thumbs Up
Post #26652 28th Aug 2010 1:46pm
liverpoolphil
or gearbox....
any way to distinguish this from the diff??
Post #26654 28th Aug 2010 1:50pm
Pauld
both have the same symptoms, ie no drive.
Have you had a smell of burning oil?
If the diff goes you lose drive 100%
With the gearbox it can take a couple of miles to go.... and depending on how badly cooked it is may still have very limited drive, after it has cooked down.
Most likely is the diff, I have had 9 I think, and 5 gearboxes!
Post #26656 28th Aug 2010 2:03pm
liverpoolphil
Laughing Laughing I have had 9 I think, and 5 gearboxes
So I'm not doing that bad then
No, didnt smell a things just plainly lost the drive. My non-mechanical brain was telling me something was spinning and trying to engage but couldnt
Post #26657 28th Aug 2010 2:06pm
elpeede
OK ,, if you get under and take a looksey , if you have a UJ at front and rear of the front prop then it has the new prop modification. I doubt this is the case from what you say so far so its likely you only have a UJ at the end where the prop links to the gearbox.
To see if it is the front diff you have a number of options, try jacking one front wheel and turning it 360 degrees around-- if it does the diff is shot.. or at least the diff input pinion is shredded. The differentials are actually fine but the pinion is a bitch to replace as it needs diff removal , dissasembley and the new pinion on reassebly is tensioned by a collapseable spacer. the tension set by the torque required to get rotation on the shaft from static... hence they replace the whole diff.
The other way to see if it has gone which may require an assistant... open the hood, start the car and have the assistant put the car in drive.. you now stand on the right side of the car as you look at it from the front. Standing beside the wing look down to the backl of the engine bay and you should be able to see the front prop. If it is the input pinion that has failed the front prop will most likely be rotating with the clunking and chewing is actually the teeth on the pinon grating against the prop. PLEASE PLEASE PLEASE do not do this with your head under the car.. it may just grab.. hence the assistant to sit in ready to press the brake / shut down the car
Interestingly the prop shaft replacement / modification also requires removal of the input pinon flange and replacement with a different flange that mates to the new prop with UJ. Quite how Landrover to this in situ and get the tension right is a total mystery to me as they can't test the force required to roate the shaft when the input pinion is up against the rest of the diff. The collaspsable spacer is a one shot item... again this is not replaced to my knowledge when they do the prop modification. Landrover may have a cunning way to do all this but I strongly suspect they just winged it. On the bright side I've yet to hear of a modified prop letting go.
I only know all this as I had to rebuild the front diff on my 101 and it was a real learning curve I'll tell you .. all the principles of setting the input pinion correctly are the same on the BMW / Range Rover unit.
The bonus is that if it is this Landrover should replace the diff and also fit the new prop modification at the same time.. Make sure you prompt them for the modified prop mind!
Post #26663 28th Aug 2010 4:20pm
Fox
That sounds expensive. Shocked
Post #26664 28th Aug 2010 4:20pm
Page 1 of 3 123>
