![]() | Home > General > No Drive |
liverpoolphil Member Since: 28 Jan 2010 Location: Lancashire Posts: 111 ![]() ![]() ![]() |
great post elpeede thanks |
Pauld Member Since: 15 Mar 2010 Location: Sheffield Posts: 199 ![]() ![]() ![]() |
that looks expensive |
a broken switch on an FFRR is expensive, question is......is this the diff gone? (covered by recall |
Not covered, this would result in loss of drive, even with a good diff |
Discocuzzy Member Since: 02 Aug 2010 Location: Surrey Posts: 94 ![]() |
Looks like drive shaft from the diff to a knackered drive hub, if so wont be covered |
out of interest, would you consider the drive shaft replacement as a difficult (technical) job?
Phil i would get the motor checked first to see if its only the half shafts (these are the ones that come out of the diff to the drive flanges on the wheels)
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2040 ![]() ![]() |
Phil
its acutally the whole left wheel unit, so I assuming if anything else in that area has gone, a total replacement may be the answer
the fleabay guy let me down |
Try Famous Four for parts, may be a better price..
cheers Paul - famous four is slightly better at 260+VAT
CWs 4x4
