Home > Technical (L322) > bad smoking on start up
lee58uk
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
hi 2006 RR SC, 69k with BRC LPG kit on drives great but the last couple of days in the morning i get big cloud of white/blue smoke on startup it clears and all seam ok. it did it agin this morning, is this valve stem seals already at 69k? or is there any common issues that anyone else knows of?
cheers
Post #266184 19th Jun 2014 8:24am
Would seem like VSR due to the LPG kit? Does it have flashlube? Don't here of too many people on here that have suffered with VSR Confused
Post #266195 19th Jun 2014 9:34am
lee58uk
Hi yes it has flash lube. It looks like the oil pipe is tee into the the 2 round lpg units that feed the gas injectors. The lub has dropped alot more than usual.
Post #266209 19th Jun 2014 10:07am
If you over lube it, it will smoke like a pig... Thumbs Up
Post #266338 19th Jun 2014 9:49pm
lee58uk
I had another look at the flashlube bottle setup. There are two lpg regulators with what looks like a vac hose coming off and going under the engine cover. The lub bottle is tee into this. I turned the screw valve on the bottle it only turned about 3/4 of a turn to close off. Didn't seem muvh
Post #266343 19th Jun 2014 10:11pm
Swithins
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
White smoke on start up
Hi all, just had my 4.2sc with BRC and flashlube serviced and was ok. A few weeks later and just had LPG service, guy upped the flashlube drip as was hardly using any and now I get thick white smoke on startup a and no other time. Just switched it off for 10 mins started it again and no smoke. The car is parked on a steep drive. Oh and at regular service had new coolant bottle.
Caar has only done 57k miles, £20k on LPG Current:
1999 SL500
2006 Mini One Chrome wrapped
2008 FFRR 4.2sc
Post #386128 9th May 2016 7:38pm
dingg1
Panic ye not , it'll just be the lube oil for the lpg system , depending on how its plumbed in
Post #386162 10th May 2016 7:17am
Swithins
Cheers, seeing the LPG guy this morning. Totally trust him even though I have only just started using him as he showed me that others hadn't been servicing the car despite charging me for the last 4 years!!!! Current:
1999 SL500
2008 FFRR 4.2sc
Post #386172 10th May 2016 8:50am
Swithins
Smoking from car no fixed. Too much valve saver fluid was the culprit. Very very happy it wasn't anything else. Current:
1999 SL500
2008 FFRR 4.2sc
Post #390785 8th Jun 2016 4:12pm
