![]() | Home > Maintenance & Mods (L322) > wheel arch rubber seal |
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 ![]() ![]() ![]() |
I intend to do this and sort the small rust bubbles in the rear door area. Hope to get it all done in a month or so.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8521 ![]() ![]() ![]() |
If your Rangie is getting a bit old, take off the sill trims, push fit fittings underneath and then just pull it hard to release the numerous clips, and have a look at the rear of the sills.... If you need to remove the jacking points, prise out the plastic peg in the middle and they pull off
__________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Don't know why the pic is upside down, definitely wasn't standing on my head!!! Pete
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 ![]() ![]() ![]() |
Just ordered my rubber strips!! |
Daft question.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7905 ![]() ![]() ![]() |
I've left mine with vasalene in and just check it every so often. I don't spray water at it.
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
Just done my arches using the strip recommended by NiceDayForIt (thanks for the tip)
archermav Member Since: 01 Jun 2015 Location: Black Country Posts: 353 ![]() ![]() ![]() |
Dragging up an old thread, but having had my ever ever ever so slightly rusty arches sorted yesterday, I've also bought the plastic strip. My rather daft question is, the original strip on the rear of the arch is coming away, however the arch itself is fine. Am I best just to replace it with the new plastic ones or try and get something to stick it back down?
Replace with new plastic ones |
lovely, will sort it tomorrow (if it ever stops raining).
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
nicedayforit Could you please post a picture of these in place? I would like to compare the appearance to the LR strips. ![]() ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- Last edited by DrRob on 13th Oct 2019 7:32pm. Edited 2 times in total |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
I really wanted one continuous strip front to back so I bought something similar to the ebay link in rubber.
If it ever stops raining I will take a picture and post tomorrow for those interested. |
As requested.
Looking up at rear of wheel arch
Sorry about the second photo, it's almost impossible to show the strip clearly against the black wheel arch liner. |
