Home > Technical (L322) > air suspension filter
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
i was reading the autocar buying guide and they mentioned that most garages overlook the air suspension filter when servicing, where is this located on the vehicle and does anyone have a part number for it ? 2002 td6 vogue, 06 supercharged facelift
Post #26400 25th Aug 2010 8:02pm
dan_uk_1984
They may mean the "Dryer" it's filled with desiccant which absorbs all the water. It's not a filter as such, but should be replaced if you live in a very damp climate, as the EAS drawers air from inside the car you should always leave the A/C on.
A symptom of this is your EAS freezing, literally. Tiny water droplets get into the valve block, this freezes and then partially opens the valves which causes leaks all over the place. Or errors when you first start up because the valves are frozen shut. If you get any moisture inside the compressor at rest then the cylinder can "pitt" which causes premature failure of the piston seal.
All of the above can usually be avoided if you leave the A/C on in the car as it dries the air, or if you replace the dryer.
Dan
Post #26404 25th Aug 2010 8:13pm
where abouts is it dan and how can we check its ok... ... - .- -.
Post #26424 26th Aug 2010 9:29am
dan_uk_1984
Seems to all be in the compressor box housing:
"Attached to the compressor is the air dryer which contains a silicate box for removing moisture from the compressed air. Air supplied to inflate the air springs passes through the air dryer. When the air springs are deflated, the exhaust air also passes through the air dryer, removing the moisture from the unit.
Attached to end of the air dryer unit is a solenoid operated exhaust pilot valve. This valve is opened when the air springs are to be deflated."
Post #26700 29th Aug 2010 12:38pm
dan_uk_1984
Air dryer unit:
http://cgi.ebay.com/ebaymotors/LAND-ROVER-...0469524227
Post #28018 14th Sep 2010 9:08am
just caught up with this post , thanks dan... Thumbs Up ... - .- -.
Post #28020 14th Sep 2010 9:54am
darrenmax
where is it hidden in the car ? 2002 td6 vogue, 06 supercharged facelift
Post #28034 14th Sep 2010 4:47pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
The air suspension compressor box is underneath the spare wheel ,it's underneath the large black metal cover (which the spare wheel bolt/retainer screws into from memory). The box also has a seal between it and the floorpan. The common issue with the EAS failing is a bog-standard valve (similar to those used on air tools) getting blocked (covered somewhere on the forum). I'll let the more techie RR boys correct me if I'm wrong though. Smile Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #28069 15th Sep 2010 12:10am
darrenmax
when i opened the compressor up last week that air dryer in your link was definately not inside the compressor housing 2002 td6 vogue, 06 supercharged facelift
Post #28107 15th Sep 2010 6:28pm
