![]() | Home > Technical (L322) > Front left driveshaft failure |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
For some time now I have been getting a bit of noise from the front left of the car and even more when turning tightly so eventually got underneath and found the LH front drive shaft had lots of play, assumed it was a CV joint away.
dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014 ![]() ![]() ![]() |
You have a limited slip (Torsen) center diff so this would have locked and you would have been rear wheel drive only. The driver is supposed to be unaware of it's operation, but although very very smooth when kicking in there is usually a very slight delay before moving off. Although with an Automatic you may not notice this at all I supose.. http://en.wikipedia.org/wiki/Torsen#Notable_Torsen_users In Ye-Olden-Days you could remove the prop on a Range Rover and just lock the diff and drive on 2wd only. It's common with the Freelander that the center diff seizes, so people just take one of the props off! ![]() |
Thanks dan, I suspect I have done about 10k miles towing with it like that, did suspect it was not as good as it should be towing vans in thick mud last year.
SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 ![]() |
Common on the P38 too. Viscous goes solidus. |
