![]() | Home > Technical (L322) > gearbox problem |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
.......Just checking but is your tickover a little high by any chance? 5.0 supercharged autobiography
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Hi jonno
Hi Greg,
Cheers jonno |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
If it's got 20's the vibration is escalated. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
Does your newly purchased RR have larger than 18" alloy's on by chance? If so, the vibration is absolutely normal... Plenty to read on the net about the driveshaft vibration issue (hence JLR only selling the early TD6 with 18" wheels) In 2006 JLR made the driveshafts a couple of mm longer or shorter??? to resolve these issues ![]() The 4.4 petrol model had 19" & 20" wheels so your car may have been retro fitted with petrol model sized wheels ![]() Most on here with TD6's fitted with bigger wheels just put up with the vibration and or put in "N" when stopped at traffic lights etc ![]() |
Thanks for the replies lads
Probably down to a driveshaft or hub unit then my friend... Well worth getting checked out by a gearbox specialist though |
Thanks for all your suggestions, been to cannock today not rolling road (me getting confused) but a good road test
