Home > In Car Electronics (L322) > Fault codes / ENgine power |
jaipal2004 Member Since: 13 Dec 2013 Location: Wednesbury, West Midlands Posts: 85 |
Hi,
27th May 2014 2:57pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1320 |
sounds like a bodge fix (emulator) to stop you getting CEL when running on lpg
27th May 2014 7:22pm |
Thanks dingg1....
27th May 2014 8:06pm |
I'd guess it would go to the emulator itself |
27th May 2014 10:29pm |
Thanks again
27th May 2014 10:47pm |
its not normal , if the lpg is set up properly and mapped well it shouldn't need an emulator fitting , its usually fitted by installers whoa re struggling a bit with mapping or the lpg system fitted isn't up to the task.
27th May 2014 10:52pm |
Thanks for the pointer.
27th May 2014 10:55pm |
Well I've cut the unidentified wire and have managed to get some successful connections with my simple ELM bluetooth interface
29th May 2014 4:26pm |
the lean codes will be what the emulator was masking , now that you've chopped it out (brave without knowing what it was ) you can see them with your reader , are they pending codes or confirmed ? if confirmed they should be lighting up the warning lamp.
29th May 2014 4:37pm |
I thought I'd take the punt and chop it - I've got a pair of pliers in the car just in case I have to connect it up again whilst on the road!
29th May 2014 4:40pm |
If they're pending they'll light up the CEL (IF ITS WORKING) after 3 or 4 running cycles of the engine
29th May 2014 5:06pm |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 |
Just wants a retune...........the reason it probably goes well at 50mph + when accelerating is that the fuel system goes into open loop and does not require the 02 sensors. below that ant the system needs an lpg map and both working sensors. IF the sencors are ok(check the short term fuel trim on your ELM) then the map wants modifying. Which gas system have you got? 5.0 supercharged autobiography
29th May 2014 10:14pm |
Thanks for the response mate.
29th May 2014 10:41pm |
Hi,
2nd Jun 2014 10:29pm |
