Home > Maintenance & Mods (L322) > Air Con is STILL NOT WORKING |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
Hopefully Duckworths can give you a price on the new hose you need. |
19th May 2014 4:22pm |
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 |
You are right and that is exactly what I intend to do.
19th May 2014 6:11pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
19th May 2014 7:03pm |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
Anybody with an AC leak needs to take it to an ACspecialist IMHO. Modern day refrigerants are made up of a blend of different gases which in turn have different size molecular structure and because of this a very tiny leak will let smaller gas molecules leak away leaving behind a residue of an unbalanced refrigerant gas. No amount of regassing and top up will put this blend back to what it was originally so it needs tackling by an expert in this field, vacuumed out, tested, repair to leaks and re gassed. Agueroooooooooo. 93-20
20th May 2014 7:00am |
So I have replaced the damaged pipework, took it to a AirCon specialist who cleaned the system and did a vacuum test. All good with no leaks. Recharged the system, still not working. He didn't have time to do any more work on it this weekend so I need to take it back in a week or so. In the interim and to save a bob or two, is there anything I can check myself?
24th May 2014 2:46pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
i have the 4.4 v8 model. i needed a new pump i researched the actual pump and it was a denso. (3bolt) cant remember the model BUT i think it was the same as the td6. maybe 'denso 10s17c' once you have the delco model, you can find a supplier. i saw one supplied from poland for £220 outright sale, new not exchange. however i was even luckeir to find one from a bmw x5 v8 fitted as same engine ect. it was secondhand,(not recommended) but for the price it was a no brianer to prove my fault. fitted and all ok. what you need to know know after changing that hose, and regassed, is, have you got the pump 'engaging' without putting fingers/face near to the running engine. holding a torch shining to the front of the pump, you willl see a flat wheel disc on the front face, about 10mm thick, and 100mm accross, behind that is there is a thinner disc attached, of about 4mm and a small 2mm airgap behind it. this electrically clutches the spinning serpentine belt grooved wheel. Get someone (with engine running) to operate the aircon setting., ie the light to go on, and watch for the airgap to disapper. you might hear it 'click' and see the disc spin up. -then at least you are pumping the gas! (theretically) if not, (stop engine) check for the electrical connection on front of pump. bullet connector. a signal voltage comes through it to engage etc. perhaps connect the loom side to a 12v meter, and earth and see if command signal is switching. just found an ebay pic link
27th May 2014 1:23pm |
Thank you johnboyairey . That is not to basic at all. I need all the help I can get. I will check that out a little later (if the rain eases up) |
27th May 2014 4:21pm |
I have had a look at the front of the aircon pump, can't see any seperate plates.
27th May 2014 5:48pm |
i cant really tell with those pics. but yes, have a better look tomorrow. with engine switched off, you should be able to turn that front part by hand. there is a small 12mm nut in middle. BTW what engine is this please.. to replace that pump you are going to have to bleed down the gas you just had pumped in. it is illegal to just vent it, and dangerous to you and pets, and your wallet if caught. you could get it vacuumed at your aircon garage. try and get a better pic first and post.
27th May 2014 9:57pm |
Yeah thanks, I got all of that. The engine is a 3.0 TDV6. On the pictures in the links you have sent me, there is a domed disc on the outside of the "belt Wheel" part. This is not there on mine and I cant seem to find anything that will turm by hand. I am now thinking that this "clutch" part is missing. When I have time and I can get under the car (weather permitting) I will geta better look at it.
27th May 2014 10:23pm |
It should look like this one i just clicked your profile it says you are a 2003 td6 not a tdv6 you have a straight six td6 yes? if its a td6 it will look like this
28th May 2014 7:15am |
Hi iphs,
28th May 2014 10:25am |
First of all, thanks to all of you for the replies. I do appreciate them all.
28th May 2014 5:43pm |
You are missing the front half of the compressor clutch
30th May 2014 7:02pm |
