Home > In Car Electronics (L322) > Koolertron touchscreen upgrade in RR2003 Vogue, no sound |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35284 |
maybe a picture of the unit might help, it could be called by another name [badged] ... - .- -.
19th May 2014 7:58am |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
If it's the Chinese type unless it was the older non screen setup it won't as it's got amps in the boot you have to rewire all speakers and such if it is _____________________________________________________
19th May 2014 8:28am |
AndyBunn Member Since: 13 Dec 2013 Location: hampshire Posts: 13 |
I was sent a new loom with the stereo that runs to the rear of the car that connects to the rear of the car.
19th May 2014 10:30am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
I would imagine you take the existing connection from the bm54 radio unit in the boot, connect it to one end of your new loom, and then connect the other end of the new loom to the bm54.
19th May 2014 11:07am |
If the BM54 is the little silver box I have done that. it all worked but no sound. the cable on the right does not go any where. I also connected the antenna from the head unit to the little square looking connection on the top of the silver box. still no sound.
19th May 2014 11:19am |
I'm just guessing here, but there was a Nokia phone kit loom attached to my car which I removed, and I had to take the smaller sub blocks out of the big connector that's on the car, and put them in the same place on the new plug, before attaching back to the bm54 if that makes any sense ?
19th May 2014 11:36am |
On your pic above, one of the sub blocks is a white plug.....
19th May 2014 11:37am |
Ive changed the sub blocks over (white and black) and still no sound.
19th May 2014 1:25pm |
I must admit to being a little stumped then.......
19th May 2014 1:42pm |
the sound works on the standard fit stereo. But has never worked on the new unit. Im also very puzzled. Its supposed to be plug and play..... |
19th May 2014 1:52pm |
I know what you are saying........
19th May 2014 1:59pm |
probably a stupid question but is the volume turned up? ... - .- -.
19th May 2014 2:02pm |
the volume is up and I double checked the mute...just in case.. I have been known to over look the easy solutions...lol http://www.fullfatrr.com/forum/images/smiles/icon_lol.gif |
19th May 2014 2:10pm |
Good point Stan......
19th May 2014 2:12pm |
