Home > In Car Electronics (L322) > Koolertron touchscreen upgrade in RR2003 Vogue, no sound
Page 1 of 3 123>
AndyBunn
I have recently purchased a touch screen upgrade to my RR2003 Vogue( Koolertron, Chinese model)
I am having trouble with the wiring harness they have sent.
I have managed to get the screen working and all components of the unit work i.e GPS, DVD, Stereo, etc
But I cant get no sound.
I have searched this forum and others but after a mind bending four hours, I am now asking my fellow Range rover owners if they have any idea what I need to do.
Many thanks
Andy
Post #260194 19th May 2014 8:54am
maybe a picture of the unit might help, it could be called by another name [badged] ... - .- -.
Post #260197 19th May 2014 8:58am
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
If it's the Chinese type unless it was the older non screen setup it won't as it's got amps in the boot you have to rewire all speakers and such if it is _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #260202 19th May 2014 9:28am
AndyBunn
I was sent a new loom with the stereo that runs to the rear of the car that connects to the rear of the car.
The connecter on the far left fits into the little silver box (tuner box I think). Not to sure were the four wires go.
The connecter in the middle connected to the cars wiring loom.
The connecter on the right does not fit anywhere.
I also have an antenna cable which I presume also fits into the tuner box.
I hope this helps .
many thanks
andy
Post #260224 19th May 2014 11:30am
mjdronfield
I would imagine you take the existing connection from the bm54 radio unit in the boot, connect it to one end of your new loom, and then connect the other end of the new loom to the bm54.
Not done it myself though...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #260234 19th May 2014 12:07pm
AndyBunn
If the BM54 is the little silver box I have done that. it all worked but no sound. the cable on the right does not go any where. I also connected the antenna from the head unit to the little square looking connection on the top of the silver box. still no sound.
many thanks
Post #260240 19th May 2014 12:19pm
mjdronfield
I'm just guessing here, but there was a Nokia phone kit loom attached to my car which I removed, and I had to take the smaller sub blocks out of the big connector that's on the car, and put them in the same place on the new plug, before attaching back to the bm54 if that makes any sense ?
So it may be that if you just swap the plugs, not all the existing connections are there. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #260243 19th May 2014 12:36pm
mjdronfield
On your pic above, one of the sub blocks is a white plug.....
Yes, that's the bm54 module......
Sorry, looking at your other pics, the sub blocks are not there. You will def need to move them across as you swap the plugs.
All the wires that are on your big plug now, will need to be there after you have finished.
Pretty sure that will sort your issue, as the sub blocks take the aux in feeds I believe.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #260244 19th May 2014 12:37pm
AndyBunn
Ive changed the sub blocks over (white and black) and still no sound.
Post #260283 19th May 2014 2:25pm
mjdronfield
I must admit to being a little stumped then.......
Did it work before, if thats not a daft question ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #260285 19th May 2014 2:42pm
AndyBunn
the sound works on the standard fit stereo. But has never worked on the new unit. Im also very puzzled. Its supposed to be plug and play.....
Post #260287 19th May 2014 2:52pm
mjdronfield
I know what you are saying........
Essentially, whats there as standard needs to still be connected and pass through your new unit I believe.
I have not changed mine I'm afraid so don't have first hand knowledge.
Others have on here and will be able to advise better...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #260288 19th May 2014 2:59pm
probably a stupid question but is the volume turned up? ... - .- -.
Post #260289 19th May 2014 3:02pm
AndyBunn
the volume is up and I double checked the mute...just in case.. I have been known to over look the easy solutions...lol http://www.fullfatrr.com/forum/images/smiles/icon_lol.gif
Post #260293 19th May 2014 3:10pm
mjdronfield
Good point Stan......
I can see from the pics, that the left hand and middle plugs will be to do with the big multi plug on the BM54 module. They match the profile.
As stock, the BM54 then sends line level signals to the DSP unit, that feeds the speakers.
If the standard plug to the BM54 is totally removed, there will be no feed to the DSP and thus no sound.
Somehow you still need to feed the DSP.......so the inputs (to the BM54) need to come from the connections on the new unit, but the outputs need to go into the DSP on existing standard wiring, hence the looms having to be linked together.
Perhaps I've mislead you with the sub connectors. It'll be something to do with that.
What does the plug on the right on the pics on the new unit do then ?
Has that got a label on ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #260294 19th May 2014 3:12pm
Page 1 of 3 123>
