Home > Maintenance & Mods (L322) > Autoglym Oven Cleaner
mjdronfield
Yes, get your point, but it does take the crud off where previous owners have neglected and the alloys have gone more "gold" in the corners. Perhaps thats just the scrubbing then. Just a way of getting it cleaner at the start of my ownership.
A proper alloy cleaner is prob best, but I do it just the once, and then use AG's silicone resin polish and top up as needed.
I don't tend to let my wheels get too dirty. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #259659 16th May 2014 8:54am
I blame TV advertising .
Post #259711 16th May 2014 12:51pm
Asked SWMBO for some Mr Muscle Oven Cleaner on the weekly shop, and ran a test on one of my front wheels, which suffered from the dreaded black streaking that you can't wash off.
1. Quick rinse over with water to remove any surface dirt
2. (Using correct PPE) sprayed foam onto affected area of wheel
3. Walked away for 15 minutes (but you could leave for 30 minutes)
4. Light (and I mean light) scrubbing with a wheel brush.
5. All black streaking gone, and no apparent side effects
SWMBO was also impressed Very Happy - now I have to clean the oven Rolling with laughter .
Post #260388 19th May 2014 8:28pm
pld118
Told you all! Baked or caked, your dishes will more oven than not be clean if you properly use Mr M!
Post #260391 19th May 2014 8:36pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Shocked
Good result with Mr M there PLD Thumbs Up Thumbs Up
I'm going to have to try this little trick with Mr M. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #260392 19th May 2014 8:44pm
neo
England 2013 Range Rover Vogue SDV8 Santorini Black
Its amazing what you can learn online .......... Smile
I would assume that if you have damaged alloys it may be a bit to risky? or try masking those areas off?
Post #260529 20th May 2014 4:02pm
pld118
@neo - If you're thinking that any surface breaks or imperfection might allow the Mr M to go to work underneath and blister the surface from the inside out, then I supposed you could try and protect such areas... unless you're planning on a formal alloy/ cosmetic refurb soon and you could try not protecting as an experiment! Mr. Green
Not sure the answer to that in truth but I've been using it on cars from time to time for a number of years and have never had a problem, although the alloys haven't had pre existing damage. I do use a slow cold water tap setting on the hose gun to carefully wash the Mr M off though, as opposed to the spray settings.
Post #260562 20th May 2014 7:34pm
marshy
Australia 2002 Range Rover HSE 4.4 V8 Buckingham Blue
Hey guys with that mr muscle oven cleaner doing such a good job on alloy wheels would it work on alloy bullbars.??
Post #261153 24th May 2014 1:03am
try it and see Thumbs Up ... - .- -.
Post #261172 24th May 2014 8:45am
Remember all Mr M is doing is removing dirt, it won't make it shiny unless it is already shiny underneath all the dirt! .
Post #261174 24th May 2014 8:49am
Mr Muscle Test
In between times while doing my brakes, I have set to cleaning my wheels with Mr Muscle. The outsides of my wheels are in pretty good nick but with a few brake dust streaks, the insides have probably never been cleaned since new.
A quick before and after shot:
All four inners were given a good dosing of Mr Muscle and allowed to work for 30 minutes. I then took a wheel brush and a scrubbing brush to them, but found this wasn't working, so used a well-used green scouring pad which started to shift the stubborn stuff. The inners were covered with a thick slightly greasy deposit, so I wore gloves. All four wheels needed a second application of Mr Muscles on the tough bits and further scrubbing and scouring. The outers were easy in comparison. A final wash off and polish and a pretty good result. Unfortunately, I have now become wheel anal, and will have to persist with this approach on a regular basis Thumbs Up
If I am honest, there appears to be no substitute for good old elbow grease. Mr Muscle does help to break down the caked on dirt and muck, but it still requires a fair amount of mechanical action.
Have to see how well it fares next time round - should be a breeze! .
Post #265264 13th Jun 2014 4:56pm
Winchester101
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Well done good job joe Bow down 1994 softail full stars n stripes custom harley davidson
Post #265276 13th Jun 2014 5:45pm
