Home > Technical (L322) > TD6 2002 wont start
Batpooh
United Kingdom 2002 Range Rover Vogue Td6 Galway Green
Hi Ian & Grant
The flashing lights I am unsure whether they normally flash or not but the rest of the interior of the car is alive with pulsing as if it all starts up then runs out of welly then starts again, a bit like when your battery is flat and the solenoid starts dropping out because the starter has nicked all the current.
yes i also think its a bad connection somewhere and the ignition switch has been the culprit it would appear in a few similar threads so start there £30 squids delivered .....eventually Neutral
stuart
Post #244104 21st Feb 2014 6:20pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Stuart, sounds like instrument cluster to me, had same issue with mine, I dont know how to diagnose, but indy couldt fix and had to go to main dealer, all good after that Thumbs Up
Post #244105 21st Feb 2014 6:23pm
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
Batpooh
Did you get this problem sorted as my car wont start today when I turn the key in the ignition.
Im looking along the lines of changing the "Ignition switch contact housing"
Grant
Post #259471 15th May 2014 3:57am
