![]() | Home > My Range Rover > LR corrosion warranty |
MachineHead Member Since: 20 Apr 2014 Location: The hoose Posts: 310 ![]() ![]() ![]() |
My 09 has the rear screen side trims, which the dealer says are normally only under 3 year warranty but he will try get LR to replace them. mine are corroded top and bottom both sides. I pointed out it was hardly a great advert for a luxury premium motor to have rotten peeling trims, we shall see |
Am I right in thinking that 'later' L322/ those vehicles with 'later' manufactured tailgates are less likely to suffer with tailgate corrosion, hence when people with pre 2010MY cars get new tailgates (for whatever reason) people say "at least you won't have to worry about tailgate corrosion anymore"... so... if true...
silversurfer Member Since: 24 Oct 2013 Location: londinium Posts: 84 ![]() ![]() ![]() |
When you say "rear screen side trims " are you referring to the tailgate. ? A photo would be helpful if possible. Much appreciated. ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
on the rear window you have two thin rubber strips that run down each side of the glass, these normally corrode at the bottom and sometimes at the top... ... - .- -.
Yep and they are made of cheese |
Many thanks for that ![]() Excellent forum this. |
paul r Member Since: 27 Feb 2012 Location: Nantwich Posts: 217 ![]() |
LR also refused to fix my rusty arches. They blamed it on 'stone chips' and said it was not due to a defect. It's a cheek as they don't put rubber strips on the rear arches, so in my eyes it is their fault. I sprayed the arches myself and put some strips on, from a disco I believe.
I had a quick shufty and lo and behold tell tale signs of the dreaded rust just beginning to show.
Got a call today saying LR have approved my warranty work, they took photos of tailgate and window rubbers as part of my claim. They just said the requested warranty work has been approved no mention that they wouldn't cover the rear rubbers so here's hoping.
Mark6r Member Since: 25 Jun 2012 Location: South Lanarkshire Posts: 90 ![]() ![]() ![]() |
Got a reply back today which says
It's LR who manufacture the car and it's marketed as the LR warranty.
Got a call today, your range rover can be collected tomorrow. Erm only landrover haven't agreed to do the window rubbers down the rear windscreen but they had to come off to do the work. We could try putting them back on but as the metal in them is blown it will not be easy and they may not hold. Do you want us to order new ones at �25 each?
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
I just had mine replaced by the garage under their warranty but I was wondering as older models don't have these side trims are they necessary? I know people with older models can remove the lower windscreen trim to match the new models so was thinking maybe this would be the same?
Craig (ctc) has taken his off..i dont really know what they are supposed to do tbh, unless it channels water some how.. ... - .- -.
