Home > My Range Rover > LR corrosion warranty |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35406 |
read my previous posts ... - .- -.
30th May 2014 5:54pm |
MachineHead Member Since: 20 Apr 2014 Location: The hoose Posts: 310 |
Looking at them they protect the exposed edge of the glass when the tailgate is open. To be honest I am not wholly impressed with the fitting / look of the replacements. One seems to stick out a but further at the bottom the the other. I will take pics soon I am on a busy work period at the moment. As mentioned by lolo there are slight gaps at the end but I suspect these let running water drain away as there is a v cut in them. 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts |
31st May 2014 4:01am |
Ok so I looked closely at the trims and...... am I being unreasonable here, please tell me if so.
31st May 2014 2:54pm |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 |
Here is picture of mine to compare.
31st May 2014 3:29pm |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
Bottom trip removed!! I think mine was stuck on with some type of sealant as it would not side but I cut through then carefully pulled off and it looks much cleaner as I have no side strips either. Bad point was I found more rust and a paint line where the dealer had painted up to the old trip rather than remove it but at least I can treat the rust before it goes back to them again. Looks much cleaner removed There is a difference between knowing your sh!t and knowing you're sh!t
31st May 2014 9:56pm |
Well I got my answer, fitted by National Windscreens, Inverness. The same company that caused £680 of damage just changing a front windscreen on my D3
8th Jun 2014 9:42am |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Anyone else taken these off? |
9th Apr 2015 4:12pm |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 |
Ours a 2004 and didn't come with the side trims fitted. I don't know why Land Rover decided to fit them as the car looks fine without them.
10th Apr 2015 8:42am |
Do they come off easily enough? |
10th Apr 2015 8:54am |
Don't know about the side trims. The bottom trim, I heated it up with a hot air gun and slid it out carefully.
10th Apr 2015 4:01pm |
