![]() | Home > My Range Rover > LR corrosion warranty |
If the car is less than 6 years old and has been serviced and maintained in accordance with LR guidelines yes.
MachineHead Member Since: 20 Apr 2014 Location: The hoose Posts: 310 ![]() ![]() ![]() |
Thanks, it has full LR service history, I only bought it from a small car dealer a week ago.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8703 ![]() ![]() ![]() |
If it less than 6 years old then yes, looks like a 2009 so i would reckon they would definitely cover the upper tailgate, not too sure on the window trims, as they may be excluded however it is worth a try.
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
My warranty book (version LRL 10 10 99 701) FOR MY 2007 (57) 08MY TDV8 says>
I shall pop by my LR dealer this week and speak very nicely to them, I did wonder about window trims but I shall point out it's the metal in them that's corroded and is perforated as the rubbers have warped and bits of the inside drop out and see where it gets me |
if you also fill in your car details on your profile page at the top of the page>
I do have my car details filled in on profile, I had selected buck blue cause my colour is not in list, but for some reason it won't show? |
Mark6r Member Since: 25 Jun 2012 Location: South Lanarkshire Posts: 90 ![]() ![]() ![]() |
Yep thats rust!
I will check my arches and other likely places tomorrow before phoning dealer. |
Bigglez Member Since: 17 Mar 2014 Location: London Posts: 156 ![]() ![]() |
I'll be following this as as the rubber window edges on my rear window (2010MY) are also twisted!
Checked my arches they seem to be tip top.
NMJ it's only about the money to repair more a matter of principle if you give someone a 6year anti corrosion warranty car has had all inspections up to date you should be willing to rectify any problems.
Refusal to do work hasn't been the issue for us Mark6r... we've had a nightmare.. repeat ** nightmare ** with our SC bought as A.U last year but... dealership management have not quibbled reference any matters in need of repair, including corrosion to arches and tailgate. The problem has more often than not been 'shop floor' execution of agreed/ necessary works... unfortunately that fatally undermines any statements of good management intent |
