Home > Technical (L322) > TD6 Performance Upgrades |
I'd say ;
12th May 2014 12:13pm |
Jmelvinbath Member Since: 12 May 2014 Location: Wimbledon Posts: 16 |
That sounds cool, so in addition to what i've got planned just a free flow air filter? does this effect risk of water getting in from splashes etc when wading?
12th May 2014 12:17pm |
If you want even more power, Jeremy Fearn fit a kit with a second intercooler, resulting in 250 bhp and 420 torques......
Looks quite good... I'll ring them and find what they can do... Looks like i won't be bothering with the facelift then.
12th May 2014 12:22pm |
Sorry, posted same time as you - not tuned and higher than that. Not aware of injector changes etc, but as its basically the same engine, it should work.
12th May 2014 12:24pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Sell it and get a TDV8. |
12th May 2014 3:41pm |
And then worry about turbo issues instead of gearbox ones ! 2011 Range Rover Vogue SE 4.4 TDV8
12th May 2014 3:43pm |
Thanks guys, i'll look into the air filters and see if my mate fancies having a look at the engine in more depth as well.
12th May 2014 6:08pm |
You need to do a new thread telling us about fitting your touchscreen ..........
12th May 2014 6:11pm |
Very quick summary..
12th May 2014 6:16pm |
Basically didn't want it in anyway not to look OEM, so when you have it all turned off the only bit you can see is the iPhone dock i built into the coin tray in front of the gear selector |
12th May 2014 6:17pm |
Nice job! I have a touch screen overlay in my TD6 as well.
14th May 2014 8:03am |
NicolasV Member Since: 02 Mar 2014 Location: Hoogstraten Posts: 6 |
Hi james,
14th May 2014 7:39pm |
I looked at removing the cat, but when I found out it smelled like standing behind a old ice cream van on tick over, I went off the idea....... 2011 Range Rover Vogue SE 4.4 TDV8
14th May 2014 8:10pm |
