Home > Technical (L322) > TD6 Performance Upgrades
Jmelvinbath
United Kingdom 2003 Range Rover Vogue Td6 Oslo Blue
Great ideas guys Smile couldn't do catalytic converter as live in london to spend a lot of time sat in traffic and the smell would bug me but still great suggestions Smile
Post #259426 14th May 2014 8:14pm
Riverstick
Ireland 2015 Range Rover Autobiography SDV8 Santorini Black
Re: TD6 Performance Upgrades
@jmelvinbath
The BMW M57 is a potent unit and very tuneable.
If you are going to tune one of these units in an L322, it is advisable to uprate the torque converter to something like this... http://www.roadblaster.com.au/pages/RANGE%...L40-E.html
Turbodynamics can provide an uprated turbo...http://www.turbodynamics.co.uk/shop/mdx537-stage-1-hybrid-turbocharger-for-bmw-330d-x3-p-4869.html
Our M57's are fitted with Bosch's CP1 high pressure pump which is good for 300 bhp.
I am told we would need to change the injectors also as ours are fitted with the smallest units.
And then you need a good tuner who knows his way around the Bosch ECU and the M57 and has a 4wd dynamometer to work with.
Our engines are 177bhp and around 400nms in standard form. 280~320bhp and 550~600nm of torque should be easily attainable with the modifications above and the right guy programming.
These engines are very strong and are well capable of 400bhp plus.... but when they are performing correctly, their relentless rise in torque is amazing and great fun to drive 2008 Range Rover TDV8 435,000kms
2015 Range Rover L405 SDV8 Autobiography
2008 Ford Focus1.6 tdci Titanium DPF deleted
Post #259878 17th May 2014 8:13am
Jmelvinbath
Thanks guys i'll have a look at those bits and also wouldn't do the cat bypass because of the smell and live in london and I get Censored off with how horrible the air is hahahaha
Post #260573 20th May 2014 8:21pm
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
[quote="mjdronfield"]If you want even more power, Jeremy Fearn fit a kit with a second intercooler, resulting in 250 bhp and 420 torques......
http://www.jeremyjfearn.co.uk/power.htm
Thumbs Up[/quote]
Unless he has changed his mind or can be persuaded otherwise Jeremy Fearm stop doing this modification some years ago.
Well thats what he told me about 2 years ago. Gearbox couldn't handle the power.
Gary
Post #274694 6th Aug 2014 4:34pm
mjdronfield
...in which case, I stoop corrected Thumbs Up 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #274699 6th Aug 2014 4:59pm
